주요 콘텐츠로 건너뛰기
How to Re-Align the Zipper on a Backpack
필요한 것
  1. How to Re-Align the Zipper on a Backpack, How to Re-Align the Zipper on a Backpack: 1 단계, 이미지 1/1
    • Locate the section of zipper with the problem.
  2. How to Re-Align the Zipper on a Backpack: 2 단계, 이미지 1/3 How to Re-Align the Zipper on a Backpack: 2 단계, 이미지 2/3 How to Re-Align the Zipper on a Backpack: 2 단계, 이미지 3/3
    • Take off the slider by sliding it towards the side without a stopper at the end and pulling it off.
    • Slider: the device that moves up and down the chain to open or close the zipper.
  3. How to Re-Align the Zipper on a Backpack: 3 단계, 이미지 1/3 How to Re-Align the Zipper on a Backpack: 3 단계, 이미지 2/3 How to Re-Align the Zipper on a Backpack: 3 단계, 이미지 3/3
    • Use pliers to remove at least 4 teeth on each side to leave room for a place to sew.
    • Squeezing the handles of the pliers, grab a single zipper tooth and pull it off. This may rip the zipper fabric, but you will sew it together later.
    • Be cautious that you do not get hurt from pulling the pliers back.
    • Small, sharp parts will come off during this procedure. Keep track of these small parts so you can throw them away.
  4. How to Re-Align the Zipper on a Backpack: 4 단계, 이미지 1/2 How to Re-Align the Zipper on a Backpack: 4 단계, 이미지 2/2
    • Using thread of similar color to the backpack, insert one end of the thread through the eye of the needle.
    • Let the needle slide down the thread until it hangs at the center. You should have two equal lengths of thread on either side of the needle.
  5. How to Re-Align the Zipper on a Backpack: 5 단계, 이미지 1/1
    • Tie the loose ends of the thread into a knot
  6. How to Re-Align the Zipper on a Backpack: 6 단계, 이미지 1/2 How to Re-Align the Zipper on a Backpack: 6 단계, 이미지 2/2
    • Place the slider back on the zipper.
    • The side of the slider that you feed in first has a divider in the middle.
    • Feed in one side of the zipper in at a time and pull it up to see if the slider can zip up the backpack.
  7. How to Re-Align the Zipper on a Backpack: 7 단계, 이미지 1/3 How to Re-Align the Zipper on a Backpack: 7 단계, 이미지 2/3 How to Re-Align the Zipper on a Backpack: 7 단계, 이미지 3/3
    • After putting the slider back on the zipper, sew the ends of the zipper to prevent the slider from sliding off.
    • Insert the needle through one side of the zipper fabric and pull until it stops at the knot.
    • Then, insert the needle through the other side of the zipper fabric and pull tightly until it seems secure.
    • Repeat this step as many times as needed.
  8. How to Re-Align the Zipper on a Backpack: 8 단계, 이미지 1/3 How to Re-Align the Zipper on a Backpack: 8 단계, 이미지 2/3 How to Re-Align the Zipper on a Backpack: 8 단계, 이미지 3/3
    • Tie a knot to finish it off and cut the excess thread with scissors.
  9. How to Re-Align the Zipper on a Backpack: 9 단계, 이미지 1/2 How to Re-Align the Zipper on a Backpack: 9 단계, 이미지 2/2
    • Tuck the zipper inside the flap of the backpack to cover the end of the zipper.
    • Sew the zipper fabric to the backpack to secure it in place.
결론
Test your zipper to see if it is working properly.
다른 16명이 해당 안내서를 완성하였습니다.
Emily Liu
회원 가입일: 04/28/17
557 평판
안내서 1개 작성함
UC Davis, Team S2-G1, Cole Spring 2017 UC Davis, Team S2-G1, Cole Spring 2017 회원
UCD-COLE-S17S2G1
3 회원들
안내서 6개 작성하였습니다
댓글 2개
Thanks i saved some money doing this myself. Grewt instruction
umchocky - 답글
댓글 쓰기
조회 통계:
24 시간 전: 57
7일 전: 627
30일 전: 3,070
전체 시간: 194,362
