주요 콘텐츠로 건너뛰기
How to Realign a Guitar Neck
필요한 것
  1. How to Realign a Guitar Neck, How to Realign a Guitar Neck: 1 단계, 이미지 2개 중 1개 How to Realign a Guitar Neck, How to Realign a Guitar Neck: 1 단계, 이미지 2개 중 2개
    • Place the guitar on a flat surface.
  2. How to Realign a Guitar Neck: 2 단계, 이미지 2개 중 1개 How to Realign a Guitar Neck: 2 단계, 이미지 2개 중 2개
    • Use the tuning pegs to loosen the strings.
  3. How to Realign a Guitar Neck: 3 단계, 이미지 2개 중 1개 How to Realign a Guitar Neck: 3 단계, 이미지 2개 중 2개
    • Place the alignment key on the truss rod.
    • The alignment key should fit perfectly on the truss rod in order to align properly.
  4. How to Realign a Guitar Neck: 4 단계, 이미지 2개 중 1개 How to Realign a Guitar Neck: 4 단계, 이미지 2개 중 2개
    • Gently turn the tuning key clockwise to increase the distance between the bridge and strings, or counter-clockwise to reduce the distance between the bridge and strings.
    • Twisting the key too hard might break the bridge. The twist should be smooth.
    • After one twist at the rod, be sure to check the bridge to see if it will need more aligning.
  5. How to Realign a Guitar Neck: 5 단계, 이미지 1개 중 1개
    • Tighten the strings up again using the tuning pegs.
    • Do not over tighten the strings; doing so can cause them to break.
  6. How to Realign a Guitar Neck: 6 단계, 이미지 2개 중 1개 How to Realign a Guitar Neck: 6 단계, 이미지 2개 중 2개
    • Tune the guitar using a tuner.
    • Some Dean guitars have a built-in tuner.
결승점
작성자
1다른 기여자 명과 함께
Mahbub Hasan
회원 가입일: 09/19/21
133 평판
안내서 1개를 작성함
1가이드 댓글
This is all wrong.
What's being done here is tightening the truss rod, which does NOT align the neck. You cannot change the distance between the bridge and the strings.
You do not want to fool with the truss rod unless you understand what it does and how to tell that you're doing it correctly, and this "guide" does not even begin to explain any of that.
Dan Gellert - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 16
전체 시간: 1,292
