주요 콘텐츠로 건너뛰기
How to Realign a Sliding Closet Door
필요한 것
  1. How to Realign a Sliding Closet Door, How to Realign a Sliding Closet Door: 1 단계, 이미지 3개 중 1개 How to Realign a Sliding Closet Door, How to Realign a Sliding Closet Door: 1 단계, 이미지 3개 중 2개 How to Realign a Sliding Closet Door, How to Realign a Sliding Closet Door: 1 단계, 이미지 3개 중 3개
    • Investigate the cleanliness of the tracks.
    • If the tracks are dirty, scrub them with toothbrush to clean out the dust.
    • You can use a rag or a hand vacuum to remove the loosened dust.
  2. How to Realign a Sliding Closet Door: 2 단계, 이미지 2개 중 1개 How to Realign a Sliding Closet Door: 2 단계, 이미지 2개 중 2개
    • Investigate whether the sliding door is along the top tracks.
    • If the door is completely unhooked from the top tracks:
    • Try to lift up on the door.
    • Slightly push the door in toward the closet.
    • Hook in the top rollers back onto the upper tracks.
  3. How to Realign a Sliding Closet Door: 3 단계, 이미지 1개 중 1개
    • If the bottom rollers do not align, follow these steps:
    • CAUTION: The doors may be heavy. Ask somebody for assistance.
    • Do not force anything.
    • Gently try to lift up on the door and guide its bottom rollers into the bottom tracks.
    • If the door still needs to be realigned, continue to Step 4.
    • If the door is successfully realigned with the bottom tracks, continue to Step 6.
  4. How to Realign a Sliding Closet Door: 4 단계, 이미지 3개 중 1개 How to Realign a Sliding Closet Door: 4 단계, 이미지 3개 중 2개 How to Realign a Sliding Closet Door: 4 단계, 이미지 3개 중 3개
    • Lift the top rollers up, then above and onto the top tracks.
    • This is what gives the door enough space to fit back into the bottom tracks.
    • If this doesn't work, see Step 5.
  5. How to Realign a Sliding Closet Door: 5 단계, 이미지 3개 중 1개 How to Realign a Sliding Closet Door: 5 단계, 이미지 3개 중 2개 How to Realign a Sliding Closet Door: 5 단계, 이미지 3개 중 3개
    • Another sliding door behind may be creating a space constraint.
    • Grab the sliding door that is behind it.
    • Lift it up so that the rollers at the bottom disconnect with the track.
    • Keep the top rollers connected.
    • Put down the door so that the bottom rollers are behind the track, closer to the closet.
  6. How to Realign a Sliding Closet Door: 6 단계, 이미지 3개 중 1개 How to Realign a Sliding Closet Door: 6 단계, 이미지 3개 중 2개 How to Realign a Sliding Closet Door: 6 단계, 이미지 3개 중 3개
    • Grab the door in front.
    • Attach it to both the top and bottom tracks.
    • Grab the door behind and do the same.
  7. How to Realign a Sliding Closet Door: 7 단계, 이미지 3개 중 1개 How to Realign a Sliding Closet Door: 7 단계, 이미지 3개 중 2개 How to Realign a Sliding Closet Door: 7 단계, 이미지 3개 중 3개
    • The doors should be located properly on their tracks.
    • Try to slide the doors along the tracks.
    • If they don't slide well, you may need to lubricate the tracks:
    • Grab a lubricant: olive oil, fish oil, mineral oil, or petroleum jelly.
    • Apply a small amount of the lubricant to the edge of the rag.
    • Fit the edge of the rag into the tracks.
    • Spread the rag throughout the tracks to spread the lubricant.
    • Slide the closet door along the tracks to spread the lubricant further.
결론
Thank you for considering this guide. To maintain properly working sliding closet doors, periodically clean and lubricate the tracks as described in this guide.
다른 14명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Annamarie Roger
회원 가입일: 04/09/15
500 평판
안내서 1개를 작성함
Cal Poly, Team 28-5, Green Spring 2015 Cal Poly, Team 28-5, Green Spring 2015 회원
CPSU-GREEN-S15S28G5
3 회원들
안내서 12개를 작성함
3가이드 댓글
Bonjour :)
Je suis très contente de vos explications accompagnées de photos !
Elles vont m'être très utiles pour, enfin, remettre en état mon placard coulissant ;)
Merci beaucoup ! Vous êtes géniale !
Claire.
Defontaine - 답글
Hi, so this was sorta useful for me but I still have another question. My door slides along the floor and doesn't have a bottom track. Any tips as to how I'd go about fixing it? Thanks
Flying Dolphin 101 - 답글
Very helpful, helped me fixed a cabinet door. Thanks a lot !
Mem's - 답글
댓글 쓰기
조회 통계:
지난 24시간: 31
지난 7일: 163
지난 30일: 765
전체 시간: 289,158
