주요 콘텐츠로 건너뛰기
How to Reattach Loose Book Pages
필요한 것
  1. How to Reattach Loose Book Pages, How to Reattach Loose Book Pages: 1 단계, 이미지 3개 중 1개 How to Reattach Loose Book Pages, How to Reattach Loose Book Pages: 1 단계, 이미지 3개 중 2개 How to Reattach Loose Book Pages, How to Reattach Loose Book Pages: 1 단계, 이미지 3개 중 3개
    • Open the book and remove the loose pages.
    • Make sure the pages are in numerical order.
    • Set the ordered loose pages aside.
  2. How to Reattach Loose Book Pages: 2 단계, 이미지 3개 중 1개 How to Reattach Loose Book Pages: 2 단계, 이미지 3개 중 2개 How to Reattach Loose Book Pages: 2 단계, 이미지 3개 중 3개
    • Squeeze some glue onto the inside of the book spine.
  3. How to Reattach Loose Book Pages: 3 단계, 이미지 3개 중 1개 How to Reattach Loose Book Pages: 3 단계, 이미지 3개 중 2개 How to Reattach Loose Book Pages: 3 단계, 이미지 3개 중 3개
    • Use a craft stick to spread the glue so that it covers the spine evenly.
  4. How to Reattach Loose Book Pages: 4 단계, 이미지 3개 중 1개 How to Reattach Loose Book Pages: 4 단계, 이미지 3개 중 2개 How to Reattach Loose Book Pages: 4 단계, 이미지 3개 중 3개
    • Set the ordered loose pages back in the spine.
    • Carefully line up the top and bottom of each loose page with those in the book.
    • You might need to wiggle or readjust them to make sure they are lined up.
    • Work quickly so that the glue doesn’t dry and cause the pages to stick in the wrong place.
  5. How to Reattach Loose Book Pages: 5 단계, 이미지 3개 중 1개 How to Reattach Loose Book Pages: 5 단계, 이미지 3개 중 2개 How to Reattach Loose Book Pages: 5 단계, 이미지 3개 중 3개
    • Place a rubber band around the book to hold it closed and to ensure pages are held in place.
    • Additionally, you can stack heavier books on top of your repaired book.
    • Let the book dry for 24 hours.
  6. How to Reattach Loose Book Pages: 6 단계, 이미지 2개 중 1개 How to Reattach Loose Book Pages: 6 단계, 이미지 2개 중 2개
    • Remove the heavy books and rubber band.
  7. How to Reattach Loose Book Pages: 7 단계, 이미지 1개 중 1개
    • Gently flip through your book. The pages should feel secure.
    • If the pages don’t feel secure you can repeat steps 1 through 6.
결승점
다른 4명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Carrie
회원 가입일: 03/31/22
256 평판
안내서 1개를 작성함
1가이드 댓글
Thank you , very useful . Be Lucky 🍀 Glenn.
chuckle.tometoyou - 답글
댓글 쓰기
조회 통계:
지난 24시간: 17
지난 7일: 81
지난 30일: 371
전체 시간: 22,308
