주요 콘텐츠로 건너뛰기
How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner
필요한 것
  1. How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner, How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 1 단계, 이미지 1/2 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner, How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 1 단계, 이미지 2/2
    • The leather door lining is loose.
  2. How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner, Remove plastic trim: 2 단계, 이미지 1/3 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner, Remove plastic trim: 2 단계, 이미지 2/3 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner, Remove plastic trim: 2 단계, 이미지 3/3
    • Using a plastic pry tool, carefully pry off the mock wood trim.
    • The mock wood trim tends to crack easily.
  3. How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 3 단계, 이미지 1/3 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 3 단계, 이미지 2/3 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 3 단계, 이미지 3/3
    • If any of the plastic clips come loose with the trim, remove them and press them back into the door panel.
  4. How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 4 단계, 이미지 1/2 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 4 단계, 이미지 2/2
    • Using a T20 Torx, remove the three screws located behind the previously removed trim.
  5. How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 5 단계, 이미지 1/3 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 5 단계, 이미지 2/3 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 5 단계, 이미지 3/3
    • Using your plastic pry tool, pry the door panel loose, beginning along the bottom edge and moving up each side.
    • The door panel will still be attached at the top.
  6. How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 6 단계, 이미지 1/1
    • Pull the door panel straight out along the top edge.
    • There is a series of metal clips that will pop lose.
    • When re-installing the door panel, it is important to line these clips back up with their respective holes on the door panel.
  7. How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 7 단계, 이미지 1/2 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 7 단계, 이미지 2/2
    • Unclip the internal door handle mechanism inside the door handle by rotating clockwise.
  8. How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 8 단계, 이미지 1/1
    • Unplug the speaker wire by pulling it straight out.
  9. How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 9 단계, 이미지 1/3 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 9 단계, 이미지 2/3 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 9 단계, 이미지 3/3
    • Unplug the control panel wire by rotating the lever that is built into the plug.
    • Rotate the lever from the wire side down towards the door panel.
  10. How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 10 단계, 이미지 1/3 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 10 단계, 이미지 2/3 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 10 단계, 이미지 3/3
    • Pop the light out of the bottom of the door panel and then unplug it.
  11. How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 11 단계, 이미지 1/2 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 11 단계, 이미지 2/2
    • Now that the door panel is free from the car, move it to a flat workspace.
    • Apply a line of glue along the top edge and under the middle of the leather liner.
    • Have your clamps and wood spacers ready before applying glue.
  12. How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 12 단계, 이미지 1/2 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 12 단계, 이미지 2/2
    • Push the liner into place in between the door panel sections.
  13. How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 13 단계, 이미지 1/3 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 13 단계, 이미지 2/3 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 13 단계, 이미지 3/3
    • Using several clamps and pieces of wood (to distribute pressure), clamp the liner down to the door panel.
    • You may need to add larger pieces of wood on the inside of the door panel as spacers.
결론
Allow the glue to dry following the instructions on the tube. Reassemble the door following these instructions in reverse order.
다른 3명이 해당 안내서를 완성하였습니다.
Sam A McDaniel
회원 가입일: 09/16/20
298 평판
안내서 1개 작성함
University of Memphis, Team S1-G13, Bishop Fall 2020 University of Memphis, Team S1-G13, Bishop Fall 2020 회원
UM-BISHOP-F20S1G13
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 25
30일 전: 125
전체 시간: 5,393
