주요 콘텐츠로 건너뛰기
How to Reattach a Broken Piece of Wood
필요한 것
  1. How to Reattach a Broken Piece of Wood, How to Reattach a Broken Piece of Wood: 1 단계, 이미지 1/2 How to Reattach a Broken Piece of Wood, How to Reattach a Broken Piece of Wood: 1 단계, 이미지 2/2
    • Dust the surface of the fragment and the damaged area of the furniture.
    • Any household cleaner will work; we recommend a damp rag.
    • Clean carefully, making sure not to cause further damage by splintering the fragment.
  2. How to Reattach a Broken Piece of Wood: 2 단계, 이미지 1/2 How to Reattach a Broken Piece of Wood: 2 단계, 이미지 2/2
    • Check that the fragment fits well into the break in the furniture.
    • If the fragment does not fit perfectly, cut away any irregular slivers on the fragment using a utility knife to achieve as neat of a fit as possible.
  3. How to Reattach a Broken Piece of Wood: 3 단계, 이미지 1/3 How to Reattach a Broken Piece of Wood: 3 단계, 이미지 2/3 How to Reattach a Broken Piece of Wood: 3 단계, 이미지 3/3
    • Apply glue to both the fragment and the furniture.
    • Check that the glue is spread evenly throughout both pieces.
    • Using a brush to spread the glue to all crevices is most effective.
  4. How to Reattach a Broken Piece of Wood: 4 단계, 이미지 1/2 How to Reattach a Broken Piece of Wood: 4 단계, 이미지 2/2
    • Insert the wood fragment into the glued spot on the furniture.
  5. How to Reattach a Broken Piece of Wood: 5 단계, 이미지 1/2 How to Reattach a Broken Piece of Wood: 5 단계, 이미지 2/2
    • Wipe away any excess glue using a damp rag.
    • Be careful not to move the fragment out of alignment as you are wiping.
  6. How to Reattach a Broken Piece of Wood: 6 단계, 이미지 1/2 How to Reattach a Broken Piece of Wood: 6 단계, 이미지 2/2
    • Clamp the two pieces together.
    • You can use any type of clamp that you have on hand. If you don't have a clamp, any type of clip would work.
    • Wait 30 minutes for the glue to dry before removing the clamp.
    • Be careful not to bump the fragment out of alignment as you are clamping.
결론
Continue using furniture as you had before!
다른 3명이 해당 안내서를 완성하였습니다.
Zen Miller
회원 가입일: 09/19/16
165 평판
안내서 1개 작성함
University of Minnesota, Team 1-2, Breuch Fall 2016 University of Minnesota, Team 1-2, Breuch Fall 2016 회원
UMN-BREUCH-F16S1G2
3 회원들
안내서 1개 작성하였습니다
댓글 3개
Thank you for the post. It will help me with the leg if a cigar table. However, a piece of wood broke off the front of my mom’s cedar chest and I won’t be able to use a clamp. What do you recommend?
Amanda - 답글
The clean and modern design of our products allows you to use the items for years. we are starting to sale small products and want to get your feedback for these products. We are not the World best online store but we want to be and this is only possible with your response and recommendation.
anita.6j - 답글
Very easy to follow instructions. I've found the most difficult part of any fence build is getting the posts lined up properly and getting them plumb. Even with a line, it can be tough . https://www.whitewooden.com/
White Wooden - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 23
30일 전: 80
전체 시간: 18,430
