주요 콘텐츠로 건너뛰기
How to Reattach a Cabinet's Center Stile
필요한 것
  1. How to Reattach a Cabinet's Center Stile, How to Reattach a Cabinet's Center Stile: 1 단계, 이미지 1/3 How to Reattach a Cabinet's Center Stile, How to Reattach a Cabinet's Center Stile: 1 단계, 이미지 2/3 How to Reattach a Cabinet's Center Stile, How to Reattach a Cabinet's Center Stile: 1 단계, 이미지 3/3
    • Measure the width and length of the detached center stile.
  2. How to Reattach a Cabinet's Center Stile: 2 단계, 이미지 1/3 How to Reattach a Cabinet's Center Stile: 2 단계, 이미지 2/3 How to Reattach a Cabinet's Center Stile: 2 단계, 이미지 3/3
    • Mark the measurements on the wood block that will be the supporting piece.
    • You may need to extend the length of the new stile to cover several inches above and below the stile's point of attachment.
    • Follow the markings and use the hacksaw to cut down the wood block so that it is the same width as the center stile.
  3. How to Reattach a Cabinet's Center Stile: 3 단계, 이미지 1/3 How to Reattach a Cabinet's Center Stile: 3 단계, 이미지 2/3 How to Reattach a Cabinet's Center Stile: 3 단계, 이미지 3/3
    • Apply a generous amount of wood glue to one side of the wood block.
    • Spread the glue to cover the entire side of the wood.
  4. How to Reattach a Cabinet's Center Stile: 4 단계, 이미지 1/2 How to Reattach a Cabinet's Center Stile: 4 단계, 이미지 2/2
    • Place the wood piece against the back of stile and cabinet frame.
    • Use clamps to hold the center stile, cabinet frame, and wood supporting piece together.
    • The clamps prevent the wood block from sliding off the center stile so that it will dry in a fixed position.
    • Remove the clamps after 24 hours.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Jamie Rose
회원 가입일: 01/11/22
130 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 17
30일 전: 56
전체 시간: 1,232
