주요 콘텐츠로 건너뛰기
How to Reattach a Metal Rib to Fabric Panel on an Umbrella
필요한 것
  1. How to Reattach a Metal Rib to Fabric Panel on an Umbrella, How to Reattach a Metal Rib to Fabric Panel on an Umbrella: 1 단계, 이미지 1/1
    • Open the umbrella and identify any metal ribs that have detached from the fabric panel.
  2. How to Reattach a Metal Rib to Fabric Panel on an Umbrella: 2 단계, 이미지 1/2 How to Reattach a Metal Rib to Fabric Panel on an Umbrella: 2 단계, 이미지 2/2
    • Tie a knot two inches from the end of the thread.
    • Place the opposite end of the thread into a sewing needle.
    • Rubbing or wetting the end of the thread may make it easier to insert the thread into the sewing needle.
  3. How to Reattach a Metal Rib to Fabric Panel on an Umbrella: 3 단계, 이미지 1/1
    • Align the metal rib with the region of the fabric panel that it detached from.
    • If necessary, use scotch tape to secure the metal rib into position so it does not lift up.
  4. How to Reattach a Metal Rib to Fabric Panel on an Umbrella: 4 단계, 이미지 1/3 How to Reattach a Metal Rib to Fabric Panel on an Umbrella: 4 단계, 이미지 2/3 How to Reattach a Metal Rib to Fabric Panel on an Umbrella: 4 단계, 이미지 3/3
    • Be careful to avoid injury when using a sharp sewing needle.
    • Insert the sewing needle through the umbrella fabric panel and pull the thread through.
    • Poke the sewing needle through the underside of the fabric panel on the opposite side of the metal rib and pull the thread through.
  5. How to Reattach a Metal Rib to Fabric Panel on an Umbrella: 5 단계, 이미지 1/3 How to Reattach a Metal Rib to Fabric Panel on an Umbrella: 5 단계, 이미지 2/3 How to Reattach a Metal Rib to Fabric Panel on an Umbrella: 5 단계, 이미지 3/3
    • Pull the sewing needle and thread across to wrap around the metal rib.
    • Insert the sewing needle through the fabric panel and pull the thread through.
    • Repeat Steps 4 and 5 until the metal rib is tightly secured to the fabric panel. Three additional loops is recommended.
  6. How to Reattach a Metal Rib to Fabric Panel on an Umbrella: 6 단계, 이미지 1/3 How to Reattach a Metal Rib to Fabric Panel on an Umbrella: 6 단계, 이미지 2/3 How to Reattach a Metal Rib to Fabric Panel on an Umbrella: 6 단계, 이미지 3/3
    • Remove the thread from the sewing needle.
    • Tie the loose end of the string to the end of the string with the knot from Step 2.
  7. How to Reattach a Metal Rib to Fabric Panel on an Umbrella: 7 단계, 이미지 1/3 How to Reattach a Metal Rib to Fabric Panel on an Umbrella: 7 단계, 이미지 2/3 How to Reattach a Metal Rib to Fabric Panel on an Umbrella: 7 단계, 이미지 3/3
    • Don't run with scissors!
    • Use scissors to cut off any excess thread.
    • If necessary, remove any scotch tape pieces.
결론
Repeat these steps if there are multiple detached metal ribs from the fabric panel. Once the repair is completed, the umbrella should work properly again.
Danielle Shapiro
회원 가입일: 02/18/20
148 평판
안내서 1개 작성함
UC Davis, Team S2-G5, Andersen Winter 2020 UC Davis, Team S2-G5, Andersen Winter 2020 회원
UCD-ANDERSEN-W20S2G5
4 회원들
안내서 2개 작성하였습니다
댓글 한 개
What sort of thread did you use? Yours seems quite thick, a lot thicker than the standard threads.
SBN - 답글
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 23
30일 전: 151
전체 시간: 5,616
