주요 콘텐츠로 건너뛰기
How to Reattach an Apron Strap
필요한 것
  1. How to Reattach an Apron Strap, How to Reattach an Apron Strap: 1 단계, 이미지 1/3 How to Reattach an Apron Strap, How to Reattach an Apron Strap: 1 단계, 이미지 2/3 How to Reattach an Apron Strap, How to Reattach an Apron Strap: 1 단계, 이미지 3/3
    • Use a thread color that matches your article of clothing (or whatever color you like).
    • Cut a piece of thread around 21 centimeters long.
    • Insert one side of the thread in the eye of the sewing needle.
    • You can wet the thread a bit to make it easier to insert in the hole.
    • It may help to thread the needle against a background with a contrasting color to make it easier to see.
  2. How to Reattach an Apron Strap: 2 단계, 이미지 1/3 How to Reattach an Apron Strap: 2 단계, 이미지 2/3 How to Reattach an Apron Strap: 2 단계, 이미지 3/3
    • Pull the thread to make sure it is in the hole.
    • Make sure the apron is aligned correctly.
    • Insert the needle from where you want to start to repair the fabric.
    • Begin from right to left.
  3. How to Reattach an Apron Strap: 3 단계, 이미지 1/3 How to Reattach an Apron Strap: 3 단계, 이미지 2/3 How to Reattach an Apron Strap: 3 단계, 이미지 3/3
    • Once inserted, make a knot so the thread can't move. Pull the thread as far as possible but still able to create a knot.
    • Insert the threaded needle a short distance from where you began, starting again from right to left.
    • Making two knots instead of one is helpful so it can last longer.
  4. How to Reattach an Apron Strap: 4 단계, 이미지 1/3 How to Reattach an Apron Strap: 4 단계, 이미지 2/3 How to Reattach an Apron Strap: 4 단계, 이미지 3/3
    • Use caution when handling a sharp needle.
    • Continue sewing from right to left, starting each new stitch a few centimeters from the previous stitch.
    • Make sure the thread goes all the way through.
  5. How to Reattach an Apron Strap: 5 단계, 이미지 1/3 How to Reattach an Apron Strap: 5 단계, 이미지 2/3 How to Reattach an Apron Strap: 5 단계, 이미지 3/3
    • Once you reach the end of the left side, make two small knots.
    • Begin from the bottom and pull to tighten the knot.
    • The knot should be small and tight enough to not be able to rip.
  6. How to Reattach an Apron Strap: 6 단계, 이미지 1/3 How to Reattach an Apron Strap: 6 단계, 이미지 2/3 How to Reattach an Apron Strap: 6 단계, 이미지 3/3
    • Make sure the knot is not loose.
    • Cut the excess thread with a pair of scissors.
  7. How to Reattach an Apron Strap: 7 단계, 이미지 1/3 How to Reattach an Apron Strap: 7 단계, 이미지 2/3 How to Reattach an Apron Strap: 7 단계, 이미지 3/3
    • Make sure the apron is aligned correctly and not loose from both sides.
    • Tug on the strap to make sure it is not loose.
  8. How to Reattach an Apron Strap: 8 단계, 이미지 1/3 How to Reattach an Apron Strap: 8 단계, 이미지 2/3 How to Reattach an Apron Strap: 8 단계, 이미지 3/3
    • You can iron the apron to make sure it is correctly aligned, but this step is optional.
    • Lay the strap down carefully and iron from the bottom to the top.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Magaly Valdez
회원 가입일: 04/08/21
181 평판
안내서 1개 작성함
CSU Los Angeles, Team S1-G3, Harris Spring 2021 CSU Los Angeles, Team S1-G3, Harris Spring 2021 회원
CSULA-HARRIS-S21S1G3
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 29
전체 시간: 924
