주요 콘텐츠로 건너뛰기
How to Reattach an Umbrella Strap
필요한 것
  1. How to Reattach an Umbrella Strap, How to Reattach an Umbrella Strap: 1 단계, 이미지 3개 중 1개 How to Reattach an Umbrella Strap, How to Reattach an Umbrella Strap: 1 단계, 이미지 3개 중 2개 How to Reattach an Umbrella Strap, How to Reattach an Umbrella Strap: 1 단계, 이미지 3개 중 3개
    • CAUTION: Seam rippers have a sharp blade; always use with caution and be aware of surroundings.
    • Notice how the strap is attached to the rest of the umbrella. The orientation matters.
    • Expose the broken stitching holding the umbrella and strap together.
    • Detach the two pieces by using the seam ripper to pull out the threads and rip through them.
  2. How to Reattach an Umbrella Strap: 2 단계, 이미지 1개 중 1개
    • Remove any excess thread left on the umbrella strap.
  3. How to Reattach an Umbrella Strap: 3 단계, 이미지 2개 중 1개 How to Reattach an Umbrella Strap: 3 단계, 이미지 2개 중 2개
    • Lay the umbrella strap flat, then mark the original sewing line with a piece of fabric chalk.
  4. How to Reattach an Umbrella Strap: 4 단계, 이미지 2개 중 1개 How to Reattach an Umbrella Strap: 4 단계, 이미지 2개 중 2개
    • Repeat Step 3 for the body of the umbrella.
  5. How to Reattach an Umbrella Strap: 5 단계, 이미지 3개 중 1개 How to Reattach an Umbrella Strap: 5 단계, 이미지 3개 중 2개 How to Reattach an Umbrella Strap: 5 단계, 이미지 3개 중 3개
    • CAUTION: Pins have a sharp point. Use with caution!
    • Align both pieces of the fabric together in the original orientation using the marked white lines as guidance.
    • Take one pin and push it down through both layers of the fabric above the original stitching line.
    • When the pin is halfway through the fabric, push it back up through the two layers.
    • Repeat this process for the second pin below the original stitching line.
  6. How to Reattach an Umbrella Strap: 6 단계, 이미지 2개 중 1개 How to Reattach an Umbrella Strap: 6 단계, 이미지 2개 중 2개
    • Cut 12 inches of black thread with a pair of scissors.
  7. How to Reattach an Umbrella Strap: 7 단계, 이미지 3개 중 1개 How to Reattach an Umbrella Strap: 7 단계, 이미지 3개 중 2개 How to Reattach an Umbrella Strap: 7 단계, 이미지 3개 중 3개
    • Hold the needle with the eye facing upwards, then carefully push the black thread into the needle's eye.
    • Tip: Moisten end of the thread to ease threading process and prevent fraying.
    • Taking the other end of the thread that did not go through the eye of the needle, make a small loop, and run that end of the thread through it.
    • Pull the thread to tighten and secure the knot.
  8. How to Reattach an Umbrella Strap: 8 단계, 이미지 2개 중 1개 How to Reattach an Umbrella Strap: 8 단계, 이미지 2개 중 2개
    • KEY TIP: The holes of the previous stitching should still be visible. Follow these holes for the new stitches. If they are not visible, individual stitches are around an 1/8 inch in length each.
    • Begin the stitch at the second hole in from the right.
    • Poke the needle up through the fabric from the underside.
    • Pull the needle through until the knot hits the fabric; you will feel resistance.
  9. How to Reattach an Umbrella Strap: 9 단계, 이미지 3개 중 1개 How to Reattach an Umbrella Strap: 9 단계, 이미지 3개 중 2개 How to Reattach an Umbrella Strap: 9 단계, 이미지 3개 중 3개
    • Poke the needle down through the first hole (which is to the right of the second hole).
    • While the needle is halfway through the first hole, angle it up, then poke it through the third hole.
    • Flip the fabric over to check that the needle is piercing the fabric, as shown in the third photo.
  10. How to Reattach an Umbrella Strap: 10 단계, 이미지 2개 중 1개 How to Reattach an Umbrella Strap: 10 단계, 이미지 2개 중 2개
    • Pull the needle and thread through the fabric completely until the thread is tight against the fabric.
    • Make sure the fabric is not scrunched.
  11. How to Reattach an Umbrella Strap: 11 단계, 이미지 2개 중 1개 How to Reattach an Umbrella Strap: 11 단계, 이미지 2개 중 2개
    • Repeat the same methods in Steps 9 and 10 until you have pulled the needle up through the last hole.
    • Remove the pins.
  12. How to Reattach an Umbrella Strap: 12 단계, 이미지 3개 중 1개 How to Reattach an Umbrella Strap: 12 단계, 이미지 3개 중 2개 How to Reattach an Umbrella Strap: 12 단계, 이미지 3개 중 3개
    • To complete the line of stitches, poke the needle through the hole to the right.
    • Pull the needle straight down instead of bringing it back up through the fabric.
    • Pull the thread until it is tight.
  13. How to Reattach an Umbrella Strap: 13 단계, 이미지 3개 중 1개 How to Reattach an Umbrella Strap: 13 단계, 이미지 3개 중 2개 How to Reattach an Umbrella Strap: 13 단계, 이미지 3개 중 3개
    • Flip the fabric over to see the underside.
    • Create a loop with the thread.
    • Run the needle through the open loop.
    • Pull the thread tight to create a knot.
  14. How to Reattach an Umbrella Strap: 14 단계, 이미지 1개 중 1개
    • Trim off any excess thread on the fixed umbrella strap and the body.
  15. How to Reattach an Umbrella Strap: 15 단계, 이미지 1개 중 1개
    • Pull both ends of the umbrella fabric to test the strength of stitching. The repair is now complete!
결론
Now your umbrella is ready to be used!
작성자
2다른 기여자 명과 함께
Emily-Mae McConihe
회원 가입일: 02/19/25
241 평판
안내서 1개를 작성함
UC Davis, Team 2-9, Andersen Winter 2025 UC Davis, Team 2-9, Andersen Winter 2025 회원
UCD-ANDERSEN-W25S2G9
2 회원들
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 30
전체 시간: 294
