주요 콘텐츠로 건너뛰기
How to Reattach the Head of a Mailbox to the Base
필요한 것
  1. How to Reattach the Head of a Mailbox to the Base, How to Reattach the Head of a Mailbox to the Base: 1 단계, 이미지 1/2 How to Reattach the Head of a Mailbox to the Base, How to Reattach the Head of a Mailbox to the Base: 1 단계, 이미지 2/2
    • Inspect the head of the mailbox to see where the detachment is located.
  2. How to Reattach the Head of a Mailbox to the Base: 2 단계, 이미지 1/2 How to Reattach the Head of a Mailbox to the Base: 2 단계, 이미지 2/2
    • Gather all materials needed.
    • Adhesive can be included depending on the tight fit you desire.
  3. How to Reattach the Head of a Mailbox to the Base: 3 단계, 이미지 1/3 How to Reattach the Head of a Mailbox to the Base: 3 단계, 이미지 2/3 How to Reattach the Head of a Mailbox to the Base: 3 단계, 이미지 3/3
    • Measure out the wood plank to match the length and width of the mailbox head.
  4. How to Reattach the Head of a Mailbox to the Base: 4 단계, 이미지 1/3 How to Reattach the Head of a Mailbox to the Base: 4 단계, 이미지 2/3 How to Reattach the Head of a Mailbox to the Base: 4 단계, 이미지 3/3
    • Use a hammer or mallet to nail this wood plank to the bottom of mailbox head. Use at least four nails for this task.
    • Use gloves, if deemed necessary!
  5. How to Reattach the Head of a Mailbox to the Base: 5 단계, 이미지 1/2 How to Reattach the Head of a Mailbox to the Base: 5 단계, 이미지 2/2
    • Screw the sides down for a stronger fit using at least four screws.
  6. How to Reattach the Head of a Mailbox to the Base: 6 단계, 이미지 1/1
    • Align the mailbox head back on the post.
  7. How to Reattach the Head of a Mailbox to the Base: 7 단계, 이미지 1/2 How to Reattach the Head of a Mailbox to the Base: 7 단계, 이미지 2/2
    • Hammer down the head to the post of the mailbox with at least three more nails.
    • Add adhesive if necessary for a sturdier attachment.
    • Since your hands are inside the mailbox, it may be best to use gloves for this task.
결승점
Terrell Cobbins
회원 가입일: 03/21/23
145 평판
안내서 1개 작성함
University of Memphis, Team M-3, Peters Spring 2023 University of Memphis, Team M-3, Peters Spring 2023 회원
UM-PETERS-S23SMG3
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 35
전체 시간: 314
