주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Reattach the Head of a Mailbox to the Base
필요한 것
  1. How to Reattach the Head of a Mailbox to the Base, How to Reattach the Head of a Mailbox to the Base: 1 단계, 이미지 2개 중 1개 How to Reattach the Head of a Mailbox to the Base, How to Reattach the Head of a Mailbox to the Base: 1 단계, 이미지 2개 중 2개
    • Inspect the head of the mailbox to see where the detachment is located.
    댓글 쓰기
  2. How to Reattach the Head of a Mailbox to the Base: 2 단계, 이미지 2개 중 1개 How to Reattach the Head of a Mailbox to the Base: 2 단계, 이미지 2개 중 2개
    • Gather all materials needed.
    • Adhesive can be included depending on the tight fit you desire.
    댓글 쓰기
  3. How to Reattach the Head of a Mailbox to the Base: 3 단계, 이미지 3개 중 1개 How to Reattach the Head of a Mailbox to the Base: 3 단계, 이미지 3개 중 2개 How to Reattach the Head of a Mailbox to the Base: 3 단계, 이미지 3개 중 3개
    • Measure out the wood plank to match the length and width of the mailbox head.
    댓글 쓰기
  4. How to Reattach the Head of a Mailbox to the Base: 4 단계, 이미지 3개 중 1개 How to Reattach the Head of a Mailbox to the Base: 4 단계, 이미지 3개 중 2개 How to Reattach the Head of a Mailbox to the Base: 4 단계, 이미지 3개 중 3개
    • Use a hammer or mallet to nail this wood plank to the bottom of mailbox head. Use at least four nails for this task.
    • Use gloves, if deemed necessary!
    댓글 쓰기
  5. How to Reattach the Head of a Mailbox to the Base: 5 단계, 이미지 2개 중 1개 How to Reattach the Head of a Mailbox to the Base: 5 단계, 이미지 2개 중 2개
    • Screw the sides down for a stronger fit using at least four screws.
    댓글 쓰기
  6. How to Reattach the Head of a Mailbox to the Base: 6 단계, 이미지 1개 중 1개
    • Align the mailbox head back on the post.
    댓글 쓰기
  7. How to Reattach the Head of a Mailbox to the Base: 7 단계, 이미지 2개 중 1개 How to Reattach the Head of a Mailbox to the Base: 7 단계, 이미지 2개 중 2개
    • Hammer down the head to the post of the mailbox with at least three more nails.
    • Add adhesive if necessary for a sturdier attachment.
    • Since your hands are inside the mailbox, it may be best to use gloves for this task.
    댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Terrell Cobbins
회원 가입일: 03/21/23
145 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 14
지난 30일: 70
전체 시간: 1,532
