주요 콘텐츠로 건너뛰기
How to Recharge the A/C in a 2012 Hyundai Tucson
필요한 것
  1. How to Recharge the A/C in a 2012 Hyundai Tucson, How to Recharge the A/C in a 2012 Hyundai Tucson: 1 단계, 이미지 1개 중 1개
    • Enter the car and turn on the coldest and most powerful A/C you can.
    • Make sure the A/C button is on.
  2. How to Recharge the A/C in a 2012 Hyundai Tucson: 2 단계, 이미지 1개 중 1개
    • Pop the hood open on the left side of the driver’s seat.
    • Secure the hood with the pole brace found on the left side of the engine near the low pressure fill port.
  3. How to Recharge the A/C in a 2012 Hyundai Tucson: 3 단계, 이미지 2개 중 1개 How to Recharge the A/C in a 2012 Hyundai Tucson: 3 단계, 이미지 2개 중 2개
    • Screw the hose to the top of the R134a refrigerant. Screw to the right until failure. Remove low pressure fill cap.
  4. How to Recharge the A/C in a 2012 Hyundai Tucson: 4 단계, 이미지 2개 중 1개 How to Recharge the A/C in a 2012 Hyundai Tucson: 4 단계, 이미지 2개 중 2개
    • With the A/C blowing cold and strong, attach the adapter at the end of the hose to the low pressure fill port.
    • Once the adapter is securely fastened, pull and hold the trigger with the bottle upside down.
    • You will begin to feel the bottle get cold. This is the refrigerant becoming activated.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Micah B
회원 가입일: 03/21/23
109 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 60
전체 시간: 3,833
