주요 콘텐츠로 건너뛰기
How to Refill Canon Pixma MG3550 Ink Cartridges
필요한 것
  1. How to Refill Canon Pixma MG3550 Ink Cartridges, How to Refill Canon Pixma MG3550 Ink Cartridges: 1 단계, 이미지 2개 중 1개 How to Refill Canon Pixma MG3550 Ink Cartridges, How to Refill Canon Pixma MG3550 Ink Cartridges: 1 단계, 이미지 2개 중 2개
    • Prepare materials.
    • You will need red, yellow, blue, and black ink and 4 syringes for the inks. These are available on Amazon.
    • Paper towel and gloves are not required but recommended.
  2. How to Refill Canon Pixma MG3550 Ink Cartridges: 2 단계, 이미지 3개 중 1개 How to Refill Canon Pixma MG3550 Ink Cartridges: 2 단계, 이미지 3개 중 2개 How to Refill Canon Pixma MG3550 Ink Cartridges: 2 단계, 이미지 3개 중 3개
    • Open the printer cover and take out the ink cartridge.
  3. How to Refill Canon Pixma MG3550 Ink Cartridges: 3 단계, 이미지 3개 중 1개 How to Refill Canon Pixma MG3550 Ink Cartridges: 3 단계, 이미지 3개 중 2개 How to Refill Canon Pixma MG3550 Ink Cartridges: 3 단계, 이미지 3개 중 3개
    • Remove the sticker label on the cartridge.
    • After removing the label, you will see a hole.
    • The black ink cartridge has one hole, and the color ink cartridge has three holes.
  4. How to Refill Canon Pixma MG3550 Ink Cartridges: 4 단계, 이미지 2개 중 1개 How to Refill Canon Pixma MG3550 Ink Cartridges: 4 단계, 이미지 2개 중 2개
    • For the black ink, first draw the ink into the syringe then insert the ink into the hole.
  5. How to Refill Canon Pixma MG3550 Ink Cartridges: 5 단계, 이미지 2개 중 1개 How to Refill Canon Pixma MG3550 Ink Cartridges: 5 단계, 이미지 2개 중 2개
    • The color ink cartridge will have three holes, one on the top and two on bottom.
    • Insert the red ink into the top hole.
  6. How to Refill Canon Pixma MG3550 Ink Cartridges: 6 단계, 이미지 2개 중 1개 How to Refill Canon Pixma MG3550 Ink Cartridges: 6 단계, 이미지 2개 중 2개
    • Insert the yellow ink into the bottom right hole.
  7. How to Refill Canon Pixma MG3550 Ink Cartridges: 7 단계, 이미지 2개 중 1개 How to Refill Canon Pixma MG3550 Ink Cartridges: 7 단계, 이미지 2개 중 2개
    • Insert the blue ink into the bottom left hole.
  8. How to Refill Canon Pixma MG3550 Ink Cartridges: 8 단계, 이미지 3개 중 1개 How to Refill Canon Pixma MG3550 Ink Cartridges: 8 단계, 이미지 3개 중 2개 How to Refill Canon Pixma MG3550 Ink Cartridges: 8 단계, 이미지 3개 중 3개
    • Put the sticker label backs, place the cartridges back in the printer and close the lid.
    • Now you can start printing.
결승점
다른 5명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Kayun Kim
회원 가입일: 03/24/23
277 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 15
지난 30일: 87
전체 시간: 2,025
