주요 콘텐츠로 건너뛰기
How to Refinish Wood Furniture
필요한 것
  1. How to Refinish Wood Furniture, How to Refinish Wood Furniture: 1 단계, 이미지 2개 중 1개 How to Refinish Wood Furniture, How to Refinish Wood Furniture: 1 단계, 이미지 2개 중 2개
    • Remove all hardware from the furniture.
  2. How to Refinish Wood Furniture: 2 단계, 이미지 1개 중 1개
    • Next you will need to wash any grease or contaminations before sanding.
    • Washing your furniture prior to sanding will prevent dirt, grease, and contaminations from being sanded into the surface of the furniture.
  3. How to Refinish Wood Furniture: 3 단계, 이미지 1개 중 1개
    • After the surface is dry begin sanding.
    • Remember to only sand with the grain so the sanding scratches will blend in with the grain.
  4. How to Refinish Wood Furniture: 4 단계, 이미지 1개 중 1개
    • Spray or paint on your primer prior to painting.
    • Remember if using spray paint to apply in a sweeping motion.
  5. How to Refinish Wood Furniture: 5 단계, 이미지 1개 중 1개
    • After allowing primer to dry approximately 3 hours apply paint. Allow paint 24 hours to dry.
    • If you are able to see the primer mixed in the paint, you may need to apply second coat of paint if needed.
결승점
작성자
1다른 기여자 명과 함께
Brandi T Powell
회원 가입일: 01/21/25
133 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 9
전체 시간: 153
