주요 콘텐츠로 건너뛰기
How to Refinish a Scratched Wood Table
필요한 것
  1. How to Refinish a Scratched Wood Table, How to Refinish a Scratched Wood Table: 1 단계, 이미지 3개 중 1개 How to Refinish a Scratched Wood Table, How to Refinish a Scratched Wood Table: 1 단계, 이미지 3개 중 2개 How to Refinish a Scratched Wood Table, How to Refinish a Scratched Wood Table: 1 단계, 이미지 3개 중 3개
    • Flip your table over on the tabletop or on the side if applicable.
    • Get your hex keys or screwdriver.
    • Using your tool to unscrew all of the legs on the table.
  2. How to Refinish a Scratched Wood Table: 2 단계, 이미지 2개 중 1개 How to Refinish a Scratched Wood Table: 2 단계, 이미지 2개 중 2개
    • Using a damp cloth, wipe down the tabletop and all of the legs.
  3. How to Refinish a Scratched Wood Table: 3 단계, 이미지 3개 중 1개 How to Refinish a Scratched Wood Table: 3 단계, 이미지 3개 중 2개 How to Refinish a Scratched Wood Table: 3 단계, 이미지 3개 중 3개
    • Get the 220 grit sandpaper and cut a smaller piece.
    • Sand the tabletop until all scratches are leveled with the wood.
    • Sand all of the legs.
    • You may use a sander if you do not want to sand the table by hand.
  4. How to Refinish a Scratched Wood Table: 4 단계, 이미지 1개 중 1개
    • Paint all of the legs and let them dry.
    • Be sure to mix your paint to ensure it hasn't separated before applying.
  5. How to Refinish a Scratched Wood Table: 5 단계, 이미지 1개 중 1개
    • Paint the tabletop and let it dry.
    • If using wood paint, coat the tabletop more than once.
  6. How to Refinish a Scratched Wood Table: 6 단계, 이미지 3개 중 1개 How to Refinish a Scratched Wood Table: 6 단계, 이미지 3개 중 2개 How to Refinish a Scratched Wood Table: 6 단계, 이미지 3개 중 3개
    • Line up the legs with the screw holes.
    • Hand tighten the screws and then use the hex keys or screwdriver to completely tighten.
    • Attach all legs and flip the table onto its legs.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Gurvir Boparai
회원 가입일: 01/10/22
133 평판
안내서 1개를 작성함
York University, Team R-4, Melo-Thaiss Winter 2022 York University, Team R-4, Melo-Thaiss Winter 2022 회원
YORK-MELO-THAISS-W22SRG4
1 회원
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 22
지난 30일: 66
전체 시간: 1,760
