주요 콘텐츠로 건너뛰기
How to Rehydrate a Dried Eyeliner Pen
필요한 것
  1. How to Rehydrate a Dried Eyeliner Pen, How to Rehydrate a Dried Eyeliner Pen: 1 단계, 이미지 1/1
    • Before you start, test out your dried eyeliner pen so you can compare the results at the end!
  2. How to Rehydrate a Dried Eyeliner Pen: 2 단계, 이미지 1/2 How to Rehydrate a Dried Eyeliner Pen: 2 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Remove the cap from your eyeliner pen.
    • Take a small pair of pliers and gently remove the felt rod from inside the liner.
    • Some liners may require you to unscrew the end of the liner to remove the felt rod.
    • If you do not have pliers, tweezers can also be used for this fix.
  3. How to Rehydrate a Dried Eyeliner Pen: 3 단계, 이미지 1/3 How to Rehydrate a Dried Eyeliner Pen: 3 단계, 이미지 2/3 How to Rehydrate a Dried Eyeliner Pen: 3 단계, 이미지 3/3
    • Once the felt rod has been removed, gently place the rod in a bowl of warm water for no more than 30 seconds.
    • If you notice the colour of the water starts to change, immediately remove the felt rod from the water.
  4. How to Rehydrate a Dried Eyeliner Pen: 4 단계, 이미지 1/3 How to Rehydrate a Dried Eyeliner Pen: 4 단계, 이미지 2/3 How to Rehydrate a Dried Eyeliner Pen: 4 단계, 이미지 3/3
    • Take the felt rod out of the water and immediately place it on a paper towel.
    • Gently pat the felt rod dry using a paper towel.
  5. How to Rehydrate a Dried Eyeliner Pen: 5 단계, 이미지 1/2 How to Rehydrate a Dried Eyeliner Pen: 5 단계, 이미지 2/2
    • Lastly, use a plier to fit the felt rod back into the liner pen.
  6. How to Rehydrate a Dried Eyeliner Pen: 6 단계, 이미지 1/1
    • Now test out your new eyeliner pen to see the difference!
    • The red arrow shows the before and the blue arrow shows the after.
결승점
Nuha Naushad
회원 가입일: 09/11/23
133 평판
안내서 1개 작성함
York University, Team 2-16, O'Regan Fall 2023 York University, Team 2-16, O'Regan Fall 2023 회원
YORK-O'REGAN-F23S2G16
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 23
전체 시간: 130
