주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Rehydrate a Dried Eyeliner Pen
조회수: 947
통계 보기:
지난 24시간
지난 7일:
32
지난 30일:
113
전체 시간:
947
댓글: 0
해당 안내서에 댓글을 남긴 사람이 없습니다. 첫 번째가 되시겠습니까?
Go to guide comments
완료함: 1
1명이 이 안내서를 "완료"로 표시했습니다. 다음은 귀하의 차례입니까?
즐겨찾기: 0
해당 안내서에 좋아요를 누르고 구독한 사람이 아직 없습니다. 첫 번째 주인공이 되시겠습니까?
소요 시간: 5 - 10 분
난이도: 쉬움
How many times have you had to throw your eyeliner pen in the trash because it dried out? Well, here is a solution for you that will not only provide you with a new eyeliner pen but will also save you money. Here is a guide on How to Rehydrate a Dried Eyeliner Pen using items that you already have in your house.
Note that this fix can get messy, so if there is a concern about your skin being irritated I recommend using latex gloves.
필요한 것
도구
    1. How to Rehydrate a Dried Eyeliner Pen, How to Rehydrate a Dried Eyeliner Pen: 1 단계, 이미지 1개 중 1개
      • Before you start, test out your dried eyeliner pen so you can compare the results at the end!
      댓글 쓰기
    2. How to Rehydrate a Dried Eyeliner Pen: 2 단계, 이미지 2개 중 1개 How to Rehydrate a Dried Eyeliner Pen: 2 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Remove the cap from your eyeliner pen.
      • Take a small pair of pliers and gently remove the felt rod from inside the liner.
      • Some liners may require you to unscrew the end of the liner to remove the felt rod.
      • If you do not have pliers, tweezers can also be used for this fix.
      댓글 쓰기
    3. How to Rehydrate a Dried Eyeliner Pen: 3 단계, 이미지 3개 중 1개 How to Rehydrate a Dried Eyeliner Pen: 3 단계, 이미지 3개 중 2개 How to Rehydrate a Dried Eyeliner Pen: 3 단계, 이미지 3개 중 3개
      • Once the felt rod has been removed, gently place the rod in a bowl of warm water for no more than 30 seconds.
      • If you notice the colour of the water starts to change, immediately remove the felt rod from the water.
      댓글 쓰기
    4. How to Rehydrate a Dried Eyeliner Pen: 4 단계, 이미지 3개 중 1개 How to Rehydrate a Dried Eyeliner Pen: 4 단계, 이미지 3개 중 2개 How to Rehydrate a Dried Eyeliner Pen: 4 단계, 이미지 3개 중 3개
      • Take the felt rod out of the water and immediately place it on a paper towel.
      • Gently pat the felt rod dry using a paper towel.
      댓글 쓰기
    5. How to Rehydrate a Dried Eyeliner Pen: 5 단계, 이미지 2개 중 1개 How to Rehydrate a Dried Eyeliner Pen: 5 단계, 이미지 2개 중 2개
      • Lastly, use a plier to fit the felt rod back into the liner pen.
      댓글 쓰기
    6. How to Rehydrate a Dried Eyeliner Pen: 6 단계, 이미지 1개 중 1개
      • Now test out your new eyeliner pen to see the difference!
      • The red arrow shows the before and the blue arrow shows the after.
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Nuha Naushad
회원 가입일: 09/11/23
160 평판
안내서 1개를 작성함
팀
York University, Team 2-16, O'Regan Fall 2023 York University, Team 2-16, O'Regan Fall 2023 회원
YORK-O'REGAN-F23S2G16
1 회원
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 32
지난 30일: 113
전체 시간: 947
