주요 콘텐츠로 건너뛰기
How to Reinforce a Cowboy Boot Heel
필요한 것
  1. How to Reinforce a Cowboy Boot Heel, How to Reinforce a Cowboy Boot Heel: 1 단계, 이미지 2개 중 1개 How to Reinforce a Cowboy Boot Heel, How to Reinforce a Cowboy Boot Heel: 1 단계, 이미지 2개 중 2개
    • Identify and assess the damage on the heel of your cowboy boot.
  2. How to Reinforce a Cowboy Boot Heel: 2 단계, 이미지 2개 중 1개 How to Reinforce a Cowboy Boot Heel: 2 단계, 이미지 2개 중 2개
    • Take a piece of sandpaper and sand down the inside of the broken heel.
    • This will allow the glue to adhere to a smooth surface.
  3. How to Reinforce a Cowboy Boot Heel: 3 단계, 이미지 3개 중 1개 How to Reinforce a Cowboy Boot Heel: 3 단계, 이미지 3개 중 2개 How to Reinforce a Cowboy Boot Heel: 3 단계, 이미지 3개 중 3개
    • Apply a small amount of Shoe Goo to the paintbrush.
    • Use the paintbrush to apply the glue on the inside of the broken heel.
    • Shoe Goo contains strong chemicals that are unsafe to inhale in large quantities.
  4. How to Reinforce a Cowboy Boot Heel: 4 단계, 이미지 1개 중 1개
    • Hold and apply pressure to the boot with your hands for at least 5 minutes.
    • Wait an additional 5 minutes for the glue to dry.
  5. How to Reinforce a Cowboy Boot Heel: 5 단계, 이미지 3개 중 1개 How to Reinforce a Cowboy Boot Heel: 5 단계, 이미지 3개 중 2개 How to Reinforce a Cowboy Boot Heel: 5 단계, 이미지 3개 중 3개
    • Measure the length of each side of the heel with the leather strip.
    • Cut two pieces of leather using scissors corresponding to the measured length of the right and left side of the heel.
    • If the leather strips are too thick, cut the measured leather strips vertically in half for thinner strips.
  6. How to Reinforce a Cowboy Boot Heel: 6 단계, 이미지 3개 중 1개 How to Reinforce a Cowboy Boot Heel: 6 단계, 이미지 3개 중 2개 How to Reinforce a Cowboy Boot Heel: 6 단계, 이미지 3개 중 3개
    • Apply glue to the leather strip with the paint brush.
    • Place the strip on one side of the boot along the heel.
  7. How to Reinforce a Cowboy Boot Heel: 7 단계, 이미지 2개 중 1개 How to Reinforce a Cowboy Boot Heel: 7 단계, 이미지 2개 중 2개
    • Apply glue to the other leather strip.
    • Place the strip onto the other side of the boot, so that both pieces meet at the back.
    • These leather strips will reinforce and protect your heel from detaching again in the future.
  8. How to Reinforce a Cowboy Boot Heel: 8 단계, 이미지 3개 중 1개 How to Reinforce a Cowboy Boot Heel: 8 단계, 이미지 3개 중 2개 How to Reinforce a Cowboy Boot Heel: 8 단계, 이미지 3개 중 3개
    • Rub the sponge on the mink oil for 30 seconds.
    • Apply the oil to the leather parts of the boot.
    • Mink oil waterproofs, restores, and protects the leather.
  9. How to Reinforce a Cowboy Boot Heel: 9 단계, 이미지 1개 중 1개
    • Enjoy your newly fixed cowboy boot!
    • Let the glue dry for 24 hours until wearing it.
결론
Thank you for using our guide! Enjoy your fixed boot!
작성자
2다른 기여자 명과 함께
Nat Ericksen
회원 가입일: 11/04/24
169 평판
안내서 1개를 작성함
UC Davis, Team 4-9, Vidal-Chiesa Fall 2024 UC Davis, Team 4-9, Vidal-Chiesa Fall 2024 회원
UCD-VIDAL-CHIESA-F24S4G9
2 회원들
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 34
전체 시간: 310
