주요 콘텐츠로 건너뛰기
How to Reinforce a Hammock
필요한 것
  1. How to Reinforce a Hammock, How to Reinforce a Hammock: 1 단계, 이미지 1/2 How to Reinforce a Hammock, How to Reinforce a Hammock: 1 단계, 이미지 2/2
    • Remove and discard any damaged rope from your hammock.
  2. How to Reinforce a Hammock: 2 단계, 이미지 1/2 How to Reinforce a Hammock: 2 단계, 이미지 2/2
    • Use a power drill and a 3/8 size drill bit to drill small hole in one side of the tree.
  3. How to Reinforce a Hammock: 3 단계, 이미지 1/1
    • Insert the screw eye screw into the hole and begin screwing it in to the tree until it is secured fully into the tree.
    • A screwdriver or flathead may be needed at this point to make sure the screw eye is all the way in the tree.
  4. How to Reinforce a Hammock: 4 단계, 이미지 1/2 How to Reinforce a Hammock: 4 단계, 이미지 2/2
    • Attach the metal clasp to the rings attached to the end of the hammock.
  5. How to Reinforce a Hammock: 5 단계, 이미지 1/2 How to Reinforce a Hammock: 5 단계, 이미지 2/2
    • Once your screw eye is inserted fully into the tree and your metal clasps are connected to the ends of the hammock you can attach the metal clasp to the the screw eye.
  6. How to Reinforce a Hammock: 6 단계, 이미지 1/1
    • After attaching the hammock to the tree, repeat steps 1-5 on the other side of the hammock to the other side.
    • You will want to make sure that the second tree is at least 6ft-7ft away from the first tree.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Leanne Works
회원 가입일: 07/05/23
160 평판
안내서 1개 작성함
Austin Community College, Team 1-12, Meigs Summer 2023 Austin Community College, Team 1-12, Meigs Summer 2023 회원
AUSTINCC-MEIGS-SU23S1G12
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 32
전체 시간: 177
