주요 콘텐츠로 건너뛰기
How to Reinsert a Wooden Chair Side Stretcher
필요한 것
  1. How to Reinsert a Wooden Chair Side Stretcher, How to Reinsert a Wooden Chair Side Stretcher: 1 단계, 이미지 2개 중 1개 How to Reinsert a Wooden Chair Side Stretcher, How to Reinsert a Wooden Chair Side Stretcher: 1 단계, 이미지 2개 중 2개
    • Use the sandpaper to rough up the empty dowel holes on the side stretcher and the chairs legs.
  2. How to Reinsert a Wooden Chair Side Stretcher: 2 단계, 이미지 2개 중 1개 How to Reinsert a Wooden Chair Side Stretcher: 2 단계, 이미지 2개 중 2개
    • Check if the new dowel fits through the stretcher hole and the leg hole.
  3. How to Reinsert a Wooden Chair Side Stretcher: 3 단계, 이미지 3개 중 1개 How to Reinsert a Wooden Chair Side Stretcher: 3 단계, 이미지 3개 중 2개 How to Reinsert a Wooden Chair Side Stretcher: 3 단계, 이미지 3개 중 3개
    • Using the disposable stirrer and bowl, mix a 2:1 ratio of sawdust and wood glue.
    • The final consistency should be paste-like.
  4. How to Reinsert a Wooden Chair Side Stretcher: 4 단계, 이미지 3개 중 1개 How to Reinsert a Wooden Chair Side Stretcher: 4 단계, 이미지 3개 중 2개 How to Reinsert a Wooden Chair Side Stretcher: 4 단계, 이미지 3개 중 3개
    • With the stirrer, fill in the leg hole of the broken dowel with the paste.
  5. How to Reinsert a Wooden Chair Side Stretcher: 5 단계, 이미지 2개 중 1개 How to Reinsert a Wooden Chair Side Stretcher: 5 단계, 이미지 2개 중 2개
    • Apply a glob of wood glue to the other leg's hole.
    • Use the stirrer to spread the glue around the hole.
  6. How to Reinsert a Wooden Chair Side Stretcher: 6 단계, 이미지 2개 중 1개 How to Reinsert a Wooden Chair Side Stretcher: 6 단계, 이미지 2개 중 2개
    • Insert the intact stretcher dowel into the leg hole with wood glue.
  7. How to Reinsert a Wooden Chair Side Stretcher: 7 단계, 이미지 2개 중 1개 How to Reinsert a Wooden Chair Side Stretcher: 7 단계, 이미지 2개 중 2개
    • Align the empty stretcher hole to the the leg hole filled with paste.
    • Insert the dowel and firmly push it in till it's fully submerged into the stretcher hole.
    • Insertion of the dowel will push out some of the wood paste.
  8. How to Reinsert a Wooden Chair Side Stretcher: 8 단계, 이미지 2개 중 1개 How to Reinsert a Wooden Chair Side Stretcher: 8 단계, 이미지 2개 중 2개
    • Put the legs holding the stretcher between the bar clamp's jaws.
    • Screw in the handle to clamp together the legs until it is secure.
    • Putting a cloth or barrier between the clamp and the leg can prevent possible damage to the wood's surface.
  9. How to Reinsert a Wooden Chair Side Stretcher: 9 단계, 이미지 1개 중 1개
    • Remove any wood glue or paste residue on the legs and stretcher with a damp paper towel.
  10. How to Reinsert a Wooden Chair Side Stretcher: 10 단계, 이미지 1개 중 1개
    • Leave the chair and bar clamp in place for 24 hours while the wood glue and paste cures.
    • After waiting, screw out the clamp's handle to remove it from the chair.
결론
Your chair should now resemble how it was before, with the side stretcher back in place. Happy fixing!
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Shaelyn
회원 가입일: 02/01/24
205 평판
안내서 1개를 작성함
UC Davis, Team 3-6, Andersen Winter 2024 UC Davis, Team 3-6, Andersen Winter 2024 회원
UCD-ANDERSEN-W24S3G6
2 회원들
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 19
전체 시간: 747
