이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the mounting screws from the thumb-turn side of the lock assembly using a Phillips screwdriver.
이 단계에 사용된 도구:Tweezers$4.99-
Remove the retaining clip from the back of the cylinder assembly using tweezers or pliers.
Remove the spring cover with the cylinder in the upright position using a Flathead screwdriver.
Remove the springs carefully with tweezers or pliers and set the springs aside as they will need to be put back in during reassembly.
Remove the plug from the cylinder assembly in the upright position so the bottom pins do not fall out.
Remove the bottom pins from the plug. This can be done easily by turning over the plug and dumping them out.
Place the bottom pins into the pin holes until the top of the new pin matches the shear line.
다른 16명이 해당 안내서를 완성하였습니다.
댓글 5개
worked according to the instructions
Huh?? What do you do after the last instruction?
Follow the instructions in reverse order starting from step 8.
Worked exactly as described. Watch those springs! They fly out easily, and are prone to bend when reinstalled.
