주요 콘텐츠로 건너뛰기
How to Remove Crinkles in a Jump Rope
필요한 것
  1. How to Remove Crinkles in a Jump Rope, How to Remove Crinkles in a Jump Rope: 1 단계, 이미지 2개 중 1개 How to Remove Crinkles in a Jump Rope, How to Remove Crinkles in a Jump Rope: 1 단계, 이미지 2개 중 2개
    • Clean the jump rope if it’s dirty or used, and remove the handles.
  2. How to Remove Crinkles in a Jump Rope: 2 단계, 이미지 3개 중 1개 How to Remove Crinkles in a Jump Rope: 2 단계, 이미지 3개 중 2개 How to Remove Crinkles in a Jump Rope: 2 단계, 이미지 3개 중 3개
    • Fill 3/4 of a large pot with water.
  3. How to Remove Crinkles in a Jump Rope: 3 단계, 이미지 1개 중 1개
    • Set the pot on a stove and let it reach boiling temperature.
    • Caution: Be careful when handling boiling water since it can cause burns when handled incorrectly. Have an adult help you if needed.
  4. How to Remove Crinkles in a Jump Rope: 4 단계, 이미지 3개 중 1개 How to Remove Crinkles in a Jump Rope: 4 단계, 이미지 3개 중 2개 How to Remove Crinkles in a Jump Rope: 4 단계, 이미지 3개 중 3개
    • Place a large bucket outside.
    • Place the crinkled jump rope into the bucket.
  5. How to Remove Crinkles in a Jump Rope: 5 단계, 이미지 2개 중 1개 How to Remove Crinkles in a Jump Rope: 5 단계, 이미지 2개 중 2개
    • Carefully pour the boiling water into the bucket.
    • Caution: Boiling water can cause burns, so please handle with care.
  6. How to Remove Crinkles in a Jump Rope: 6 단계, 이미지 2개 중 1개 How to Remove Crinkles in a Jump Rope: 6 단계, 이미지 2개 중 2개
    • Let the jump rope sit with the boiled water in the bucket for about 3 to 5 minutes.
    • Remove the jump rope with a pair of tongs and place them on the ground.
    • Let the jump rope cool down enough to handle but be sure that it is still warm.
  7. How to Remove Crinkles in a Jump Rope: 7 단계, 이미지 3개 중 1개 How to Remove Crinkles in a Jump Rope: 7 단계, 이미지 3개 중 2개 How to Remove Crinkles in a Jump Rope: 7 단계, 이미지 3개 중 3개
    • Find a circular object to wrap the jump rope around and slowly apply force to pull and hold it for about 2 minutes.
    • Your jump rope should now be free of crinkles and be ready to use.
    • If you still have some crinkles in the jump rope, feel free to stack weights on top of it and let it sit overnight, or follow the guide over again to get a more refined rope.
결승점
작성자
1다른 기여자 명과 함께
Fernando Pedro
회원 가입일: 03/20/21
148 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 36
전체 시간: 1,663
