주요 콘텐츠로 건너뛰기
How to Remove Cutting Board Scratches
필요한 것
  1. How to Remove Cutting Board Scratches, How to Remove Cutting Board Scratches: 1 단계, 이미지 1개 중 1개
    • Thoroughly wash the cutting board with warm water and gentle dish soap.
    • Rinse the cutting board to make sure all the soap is removed.
  2. How to Remove Cutting Board Scratches: 2 단계, 이미지 1개 중 1개
    • Pat the cutting board dry with a towel.
    • Allow the cutting board to completely air dry.
  3. How to Remove Cutting Board Scratches: 3 단계, 이미지 1개 중 1개
    • Use a fine grit sandpaper (220-grit) and gently sand the scratched sections of the board.
    • Use even pressure until the scratches disappear.
  4. How to Remove Cutting Board Scratches: 4 단계, 이미지 1개 중 1개
    • Remove any dust or residue using a damp towel.
    • Make sure the cutting board is completely clean and dry before moving on to the next step.
  5. How to Remove Cutting Board Scratches: 5 단계, 이미지 1개 중 1개
    • Pour a generous amount of food-safe oil onto the surface of the board.
    • The amount will vary depending on the size of the board.
    • Allow the oil to soak into the cutting board overnight.
    • Wipe off any excess oil.
    • If there are still scratches visible on the cutting board, repeat all steps if necessary.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Preethi Thomas
회원 가입일: 05/29/24
145 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 21
지난 30일: 59
전체 시간: 458
