주요 콘텐츠로 건너뛰기
How to Remove Hard Wax from a Wax Warmer
필요한 것
  1. How to Remove Hard Wax from a Wax Warmer, How to Remove Hard Wax from a Wax Warmer: 1 단계, 이미지 1/2 How to Remove Hard Wax from a Wax Warmer, How to Remove Hard Wax from a Wax Warmer: 1 단계, 이미지 2/2
    • Plug in your wax warmer.
  2. How to Remove Hard Wax from a Wax Warmer: 2 단계, 이미지 1/1
    • Turn up the heat nozzle to the maximum temperature.
  3. How to Remove Hard Wax from a Wax Warmer: 3 단계, 이미지 1/1
    • Allow the wax to sit for a few minutes until fully melted.
  4. How to Remove Hard Wax from a Wax Warmer: 4 단계, 이미지 1/2 How to Remove Hard Wax from a Wax Warmer: 4 단계, 이미지 2/2
    • Take a paper towel and popsicle stick and wipe up as much of the wax as you can.
  5. How to Remove Hard Wax from a Wax Warmer: 5 단계, 이미지 1/2 How to Remove Hard Wax from a Wax Warmer: 5 단계, 이미지 2/2
    • Add a tablespoon of your oil of choice to the wax bowl (suggestions: coconut oil or olive oil) and swish it around the bowl.
  6. How to Remove Hard Wax from a Wax Warmer: 6 단계, 이미지 1/2 How to Remove Hard Wax from a Wax Warmer: 6 단계, 이미지 2/2
    • Use another paper towel and popsicle stick to clean up the remaining residue.
  7. How to Remove Hard Wax from a Wax Warmer: 7 단계, 이미지 1/2 How to Remove Hard Wax from a Wax Warmer: 7 단계, 이미지 2/2
    • Turn off the wax warmer and unplug it from electrical socket.
  8. How to Remove Hard Wax from a Wax Warmer: 8 단계, 이미지 1/1
    • Once the wax warmer is cool, proceed to wipe up any excess oil with a paper towel.
결승점
MaCara Woods
회원 가입일: 08/22/23
157 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 76
