주요 콘텐츠로 건너뛰기
How to Remove Makeup Stain from Shirt
필요한 것
  1. How to Remove Makeup Stain from Shirt, How to Remove Makeup Stain from Shirt: 1 단계, 이미지 1/1
    • Place a white napkin or rag under the shirt to avoid making a mess or colour transfer into the garment.
  2. How to Remove Makeup Stain from Shirt: 2 단계, 이미지 1/2 How to Remove Makeup Stain from Shirt: 2 단계, 이미지 2/2
    • Pour micellar water over the stain
    • Micellar water can be replaced by any kind of water-based makeup remover.
    • Do not use an oil-based makeup remover as it will permanently damage the shirt.
  3. How to Remove Makeup Stain from Shirt: 3 단계, 이미지 1/2 How to Remove Makeup Stain from Shirt: 3 단계, 이미지 2/2
    • Pat the stain dry with the napkin/rag from Step 1.
    • Do not use Kleenex tissues as they will fall apart and make a mess by sticking to the fabric.
  4. How to Remove Makeup Stain from Shirt: 4 단계, 이미지 1/1
    • Wash the shirt in cold water with the detergent of your choice.
  5. How to Remove Makeup Stain from Shirt: 5 단계, 이미지 1/1
    • Pour detergent over the stain. Pour baking soda or powder over the soap.
    • The recommended measurement is 1/4 of a teaspoon of baking soda/powder but you may use more if the stain is larger.
  6. How to Remove Makeup Stain from Shirt: 6 단계, 이미지 1/1
    • Scrub the paste into the shirt with a toothbrush.
  7. How to Remove Makeup Stain from Shirt: 7 단계, 이미지 1/1
    • Let rest for 15 minutes.
  8. How to Remove Makeup Stain from Shirt: 8 단계, 이미지 1/1
    • Wash the shirt in cold water followed by lukewarm water.
  9. How to Remove Makeup Stain from Shirt: 9 단계, 이미지 1/1
    • Let the shirt air dry and iron it if necessary.
결론
Let the shirt air dry and iron as needed.
Ariana Rabbaninejad
회원 가입일: 01/11/23
169 평판
안내서 1개 작성함
York University, Team O-3, Woodhouse Winter 2023 York University, Team O-3, Woodhouse Winter 2023 회원
YORK-WOODHOUSE-W23SOG3
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 24
전체 시간: 374
