주요 콘텐츠로 건너뛰기
How to Remove Oil Paint Stains
필요한 것
  1. How to Remove Oil Paint Stains, How to Remove Oil Paint Stains: 1 단계, 이미지 3개 중 1개 How to Remove Oil Paint Stains, How to Remove Oil Paint Stains: 1 단계, 이미지 3개 중 2개 How to Remove Oil Paint Stains, How to Remove Oil Paint Stains: 1 단계, 이미지 3개 중 3개
    • Use a palette knife to scrape off the wet paint.
    • For best results, begin this process as soon as possible after staining your clothes to prevent the paint from drying entirely.
  2. How to Remove Oil Paint Stains: 2 단계, 이미지 2개 중 1개 How to Remove Oil Paint Stains: 2 단계, 이미지 2개 중 2개
    • Soak a cotton ball with the oil paint solvent, and then gently blot at the stain.
    • Caution: Oil paint solvents exude toxic fumes and can cause skin dryness or cracking upon repeated contact. Perform this step in a well-ventilated area while wearing gloves.
  3. How to Remove Oil Paint Stains: 3 단계, 이미지 1개 중 1개
    • Soak the area of the stain with cold water.
  4. How to Remove Oil Paint Stains: 4 단계, 이미지 1개 중 1개
    • Pour a small amount of dish soap onto the stain.
  5. How to Remove Oil Paint Stains: 5 단계, 이미지 1개 중 1개
    • Scrub the soap into the stain to remove the solvent residue and paint.
    • Repeat this step as many times as necessary until the stain is gone.
  6. How to Remove Oil Paint Stains: 6 단계, 이미지 2개 중 1개 How to Remove Oil Paint Stains: 6 단계, 이미지 2개 중 2개
    • Rinse out the soap and the rest of the clothes with cold water.
  7. How to Remove Oil Paint Stains: 7 단계, 이미지 1개 중 1개
    • Let the clothes air dry, and then proceed to wash and dry as normal.
결론
Through this simple process, your clothes should be restored back to their previous condition as if the paint stain never happened! Happy painting!
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Amy Marcopulos
회원 가입일: 02/02/23
172 평판
안내서 1개를 작성함
UC Davis, Team 3-7, Andersen Winter 2023 UC Davis, Team 3-7, Andersen Winter 2023 회원
UCD-ANDERSEN-W23S3G7
3 회원들
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 12
지난 30일: 47
전체 시간: 828
