주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Remove Pilling from a Patagonia Sweater
필요한 것
  1. How to Remove Pilling from a Patagonia Sweater, What is pilling?: 1 단계, 이미지 3개 중 1개 How to Remove Pilling from a Patagonia Sweater, What is pilling?: 1 단계, 이미지 3개 중 2개 How to Remove Pilling from a Patagonia Sweater, What is pilling?: 1 단계, 이미지 3개 중 3개
    • Pilling is a natural process where loose fibers on the surface of a garment tangle together, forming small balls or "pills."
    • It’s especially common on knit fabrics and garments made from short fibers like wool.
    • Pilling happens the most in high-friction areas such as elbows, wrists, underarms or beneath a backpack.
    • While pilling doesn’t affect the performance of the garment, it can make it look worn or unkempt.
    • Avoiding picking pills off by hand, this can pull out more fibers and worsen the issue.
  2. How to Remove Pilling from a Patagonia Sweater, Garments that tend to pill: 2 단계, 이미지 2개 중 1개 How to Remove Pilling from a Patagonia Sweater, Garments that tend to pill: 2 단계, 이미지 2개 중 2개
    • Some Patagonia® products that are prone to pilling include:
    • The Better Sweater®, a knit fleece made from recycled materials
    • Knit sweaters made of recycled wool or cashmere
  3. How to Remove Pilling from a Patagonia Sweater, Tools to remove pilling: 3 단계, 이미지 3개 중 1개 How to Remove Pilling from a Patagonia Sweater, Tools to remove pilling: 3 단계, 이미지 3개 중 2개 How to Remove Pilling from a Patagonia Sweater, Tools to remove pilling: 3 단계, 이미지 3개 중 3개
    • Sweater Stone - Recommended by Patagonia® for being natural and sustainable, the Sweater Stone is a pumice stone with a porous surface that gently removes pills without damaging the fabric.
    • Electric Fabric Shaver - A great investment for long-term garment care, there are many styles of electric shavers available. Most come with adjustable guards to match different fabric pile heights.
    • Lay your sweater flat on a clean surface. Focus on one pilled area at a time.
    • Hold the Sweater Stone in one and hand and use the other hand to create tension in the fabric.
    • Moving with the grain of the knit, brush the fabric in one direction.
    • Repeat in the opposite direction. To prevent snags, don't brush back and forth.
    • The stone will lift pills and may leave behind black dust. This is normal. Shake out the sweater and wipe off any dust or lint.
    • Set the shaver guard to match the pile height of your garment. For the Better Sweater®, you can remove the guard entirely.
    • Turn on the shaver, press lightly into the fabric, and move in back-and-forth or circular motions.
    • Pills will collect in the shaver’s lint cartridge, which you can empty as needed.
  4. How to Remove Pilling from a Patagonia Sweater, Results: 6 단계, 이미지 1개 중 1개
    • Compare a de-pilled sleeve to one that hasn’t been treated. You’ll see a noticeable difference in texture and appearance.
    • When done correctly, de-pilling doesn't harm the garment. Both the Sweater Stone and electric shavers are designed to remove only the loose surface fibers. Just be sure to be gentle and follow the above instructions.
결승점
다른 13명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Brittany McCrigler
회원 가입일: 03/05/12
90,618 평판
안내서 142개를 작성함
4가이드 댓글
I also have used a disposable razor to shave pills and fuzz off of Patagonia sweaters and capilene - it worked really well. Just lightly run it down the sweater. If any fuzz is persistent, do the same but perpendicular to the first direction you used. It made my sweater and capilene pants look like new again!
AE3 - 답글
Yup, right there with AE3, disposable razor: they last a long time, and they can be re-sharpened a bit by shaving a piece of glass (nothing is disposable). This sweater stone looks kinda like pumice. I’m curious about it, but I wouldn’t buy one.
Rue Koegel - 답글
Can you use a sweater stone on the Nano-Air to remove piling as well?
Trey - 답글
Can't speak to fleece or nano puffs, but with wool sweaters a stone or plucking the pills pulls fibers upward and perpetuates the problem. Best to take scissors and ever-so-carefully, holding them parallel to garment, shear the pills off.
Susan McGrath - 답글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 41
지난 30일: 203
전체 시간: 67,482
