주요 콘텐츠로 건너뛰기
How to Remove Pilling from a Patagonia Sweater
필요한 것
  1. How to Remove Pilling from a Patagonia Sweater, How to Remove Pilling from a Patagonia Sweater: 1 단계, 이미지 1/3 How to Remove Pilling from a Patagonia Sweater, How to Remove Pilling from a Patagonia Sweater: 1 단계, 이미지 2/3 How to Remove Pilling from a Patagonia Sweater, How to Remove Pilling from a Patagonia Sweater: 1 단계, 이미지 3/3
    • Lay the sweater flat on a table. Identify the pilled area of the sweater. It will be covered in little balls of fuzz.
    • Grab your sweater stone.
    • If you ever forget how to remove piling, there is a handy diagram on the back of the box.
  2. How to Remove Pilling from a Patagonia Sweater: 2 단계, 이미지 1/2 How to Remove Pilling from a Patagonia Sweater: 2 단계, 이미지 2/2
    • Working along the grain of the sweater, gently brush the sweater with the sweater stone.
    • As you use the stone you may notice a funny smell, that is a natural part of the stone which is released as it crumbles away. You will also notice small pieces of debris, as the stone cuts away pills it also breaks apart slowly. Simply shake out the sweater when you are done to remove debris.
    At this point…does all of the “stone debris” come off? Also, what about that smell, does it linger, will it come out with washing? Thank you.
    Nan - 답글
  3. How to Remove Pilling from a Patagonia Sweater: 3 단계, 이미지 1/2 How to Remove Pilling from a Patagonia Sweater: 3 단계, 이미지 2/2
    • Lift the sweater stone.
    • To prevent snags, always lift the sweater stone when changing directions.
    • Brush the sweater stone the opposite direction along the grain of the sweater.
  4. How to Remove Pilling from a Patagonia Sweater: 4 단계, 이미지 1/2 How to Remove Pilling from a Patagonia Sweater: 4 단계, 이미지 2/2
    • Continue brushing until the pilling is removed.
    • Clean your sweater stone by rubbing your hand across the stone to remove the lint.
    Will that stone smell be on your hands? How bad is that smell? Thank you.
    Nan - 답글
결승점
다른 13명이 해당 안내서를 완성하였습니다.
Brittany McCrigler
회원 가입일: 03/05/12
89,014 평판
안내서 131개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 4개
I also have used a disposable razor to shave pills and fuzz off of Patagonia sweaters and capilene - it worked really well. Just lightly run it down the sweater. If any fuzz is persistent, do the same but perpendicular to the first direction you used. It made my sweater and capilene pants look like new again!
AE3 - 답글
Yup, right there with AE3, disposable razor: they last a long time, and they can be re-sharpened a bit by shaving a piece of glass (nothing is disposable). This sweater stone looks kinda like pumice. I’m curious about it, but I wouldn’t buy one.
Rue Koegel - 답글
Can you use a sweater stone on the Nano-Air to remove piling as well?
Trey - 답글
Can't speak to fleece or nano puffs, but with wool sweaters a stone or plucking the pills pulls fibers upward and perpetuates the problem. Best to take scissors and ever-so-carefully, holding them parallel to garment, shear the pills off.
Susan McGrath - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 38
30일 전: 225
전체 시간: 62,931
