소개
If you need to access laptop internals such as the RAM, hard drive, or the motherboard, this guide will show you how to safely open the laptop for access to these components.
부품
부품은 필요하지 않습니다.
  1. Flip the laptop over, such that the bottom of the laptop is facing upwards.
    • Flip the laptop over, such that the bottom of the laptop is facing upwards.
    • Ensure that the laptop is powered off prior to following this guide.
    댓글 쓰기
  2. Pull the latch to the right of the battery to the right.
    • Pull the latch to the right of the battery to the right.
    댓글 쓰기
  3. Fixmas/픽스마스 분위기를 띄우세요
    FIXMAS12 코드로 $50 이상 구매시 $12 할인을 받으십시오
    • Pull the latch to the left of the battery to the left. Hold the latch open with a finger to prevent it from closing.
    댓글 쓰기
    • While holding the second latch from the previous step, use another hand to reach underneath the battery.
    • Pull the battery upwards and away from the laptop to remove it.
    댓글 쓰기
    • Using a JIS #00 screwdriver, unscrew the two 5 mm screws on either side of the laptop panel.
    댓글 쓰기
    • Remove the panel by pushing away from the laptop until the panel is free of the laptop.
    • Lift to remove the panel.
    댓글 쓰기
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Elliott Beckner
회원 가입일: 2018년 11월 05일
333 평판
안내서 4개 작성하였습니다
IUPUI, Team S2-G1, Baechle Fall 2018 IUPUI, Team S2-G1, Baechle Fall 2018 회원
IUPUI-BAECHLE-F18S2G1
4 회원들
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 6
지난 30일: 16
전체 시간: 16
