주요 콘텐츠로 건너뛰기
How to Remove Rust From a 2000 Honda Civic Door Handle
필요한 것
  1. How to Remove Rust From a 2000 Honda Civic Door Handle, How to Remove Rust From a 2000 Honda Civic Door Handle: 1 단계, 이미지 1/2 How to Remove Rust From a 2000 Honda Civic Door Handle, How to Remove Rust From a 2000 Honda Civic Door Handle: 1 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Heavy-Duty Spudger
    구매
    • Before beginning this guide, roll the window up of the door you will be working on, make sure the car is off, and put it into park.
    • Open the door you want to fix.
    • Use a heavy duty spudger to pry the door pull off.
  2. How to Remove Rust From a 2000 Honda Civic Door Handle: 2 단계, 이미지 1/2 How to Remove Rust From a 2000 Honda Civic Door Handle: 2 단계, 이미지 2/2
    • Use a Phillips #2 screwdriver to remove three screws in the door pull and handle.
  3. How to Remove Rust From a 2000 Honda Civic Door Handle: 3 단계, 이미지 1/2 How to Remove Rust From a 2000 Honda Civic Door Handle: 3 단계, 이미지 2/2
    • Pinch the head of the cable connected to the door pull and gently remove it from socket, before taking off the door panel.
  4. How to Remove Rust From a 2000 Honda Civic Door Handle: 4 단계, 이미지 1/1
    • To remove the interior door handle, carefully pull the plastic part that keeps the rod in place and turn clockwise, then pull the handle down and out.
  5. How to Remove Rust From a 2000 Honda Civic Door Handle: 5 단계, 이미지 1/3 How to Remove Rust From a 2000 Honda Civic Door Handle: 5 단계, 이미지 2/3 How to Remove Rust From a 2000 Honda Civic Door Handle: 5 단계, 이미지 3/3
    • Use your hands and grab the sides of the door panel and pull to disconnect the clips around the perimeter of the door interior until it becomes loose.
    • Lift the the door panel up slowly and over the lock.
    • Remove the door panel and put it to the side.
  6. How to Remove Rust From a 2000 Honda Civic Door Handle: 6 단계, 이미지 1/3 How to Remove Rust From a 2000 Honda Civic Door Handle: 6 단계, 이미지 2/3 How to Remove Rust From a 2000 Honda Civic Door Handle: 6 단계, 이미지 3/3
    • When your take your door panel off there may be a plastic sheet where the red arrow is. Remove that as well (this car did not have one).
    • Put WD-40 on the parts that you can see that have rust or aren't working too well.
    • Look through the door panel with the window fully rolled up. Spray the exterior door handle spring with WD-40 also.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Henry Solares
회원 가입일: 10/24/22
151 평판
안내서 1개 작성함
CSU Los Angeles, Team 1-99, Briggs Fall 2022 CSU Los Angeles, Team 1-99, Briggs Fall 2022 회원
CSULA-BRIGGS-F22S1G99
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 25
전체 시간: 452
