주요 콘텐츠로 건너뛰기
How to Remove Rust on Car Body
필요한 것
  1. How to Remove Rust on Car Body, How to Remove Rust on Car Body: 1 단계, 이미지 1/2 How to Remove Rust on Car Body, How to Remove Rust on Car Body: 1 단계, 이미지 2/2
    • Spray down the rust with a spray bottle mixed with water and dish soap.
    • Wipe the mixture with a microfiber cloth.
  2. How to Remove Rust on Car Body: 2 단계, 이미지 1/3 How to Remove Rust on Car Body: 2 단계, 이미지 2/3 How to Remove Rust on Car Body: 2 단계, 이미지 3/3
    • Pour a small amount of rubbing alcohol onto a microfiber cloth.
    • Clean the rusted area with the cloth to remove any contaminants.
  3. How to Remove Rust on Car Body: 3 단계, 이미지 1/3 How to Remove Rust on Car Body: 3 단계, 이미지 2/3 How to Remove Rust on Car Body: 3 단계, 이미지 3/3
    • Rub the rusted area with 80-grit sandpaper until you start seeing the bare metal.
  4. How to Remove Rust on Car Body: 4 단계, 이미지 1/2 How to Remove Rust on Car Body: 4 단계, 이미지 2/2
    • Rub the rusted area with 220-grit sandpaper until all of the rust is removed.
    • Dampen a cloth with soapy water and wipe down the sanded area.
  5. How to Remove Rust on Car Body: 5 단계, 이미지 1/2 How to Remove Rust on Car Body: 5 단계, 이미지 2/2
    • This step is to prepare your spot for spray painting.
    • Add some paper around the areas you do not want paint on. Make sure you go a little past where you are going to spray paint to blend the paint into the surrounding area.
  6. How to Remove Rust on Car Body: 6 단계, 이미지 1/3 How to Remove Rust on Car Body: 6 단계, 이미지 2/3 How to Remove Rust on Car Body: 6 단계, 이미지 3/3
    • Spray three even coats of primer, waiting at least five minutes between each coat.
    • Let the third coat sit for 15 minutes.
  7. How to Remove Rust on Car Body: 7 단계, 이미지 1/3 How to Remove Rust on Car Body: 7 단계, 이미지 2/3 How to Remove Rust on Car Body: 7 단계, 이미지 3/3
    • Spray three even coats of paint on top of the primer, waiting five minutes between each coat.
    • You can either use a color similar to your car or you can get the actual color of you car by looking for the car's color code.
    • After the final coat, wait 24 hours before removing the surrounding paper.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Robert Gutierrez
회원 가입일: 08/25/22
163 평판
안내서 1개 작성함
CSU Los Angeles, Team 10-20, Briggs Fall 2022 CSU Los Angeles, Team 10-20, Briggs Fall 2022 회원
CSULA-BRIGGS-F22S10G20
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 21
30일 전: 118
전체 시간: 1,809
