주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Remove Rust on Car Body
필요한 것
    1. How to Remove Rust on Car Body, How to Remove Rust on Car Body: 1 단계, 이미지 2개 중 1개 How to Remove Rust on Car Body, How to Remove Rust on Car Body: 1 단계, 이미지 2개 중 2개
      • Spray down the rust with a spray bottle mixed with water and dish soap.
      • Wipe the mixture with a microfiber cloth.
      댓글 쓰기
    2. How to Remove Rust on Car Body: 2 단계, 이미지 3개 중 1개 How to Remove Rust on Car Body: 2 단계, 이미지 3개 중 2개 How to Remove Rust on Car Body: 2 단계, 이미지 3개 중 3개
      • Pour a small amount of rubbing alcohol onto a microfiber cloth.
      • Clean the rusted area with the cloth to remove any contaminants.
      댓글 쓰기
    3. How to Remove Rust on Car Body: 3 단계, 이미지 3개 중 1개 How to Remove Rust on Car Body: 3 단계, 이미지 3개 중 2개 How to Remove Rust on Car Body: 3 단계, 이미지 3개 중 3개
      • Rub the rusted area with 80-grit sandpaper until you start seeing the bare metal.
      댓글 쓰기
    4. How to Remove Rust on Car Body: 4 단계, 이미지 2개 중 1개 How to Remove Rust on Car Body: 4 단계, 이미지 2개 중 2개
      • Rub the rusted area with 220-grit sandpaper until all of the rust is removed.
      • Dampen a cloth with soapy water and wipe down the sanded area.
      댓글 쓰기
    5. How to Remove Rust on Car Body: 5 단계, 이미지 2개 중 1개 How to Remove Rust on Car Body: 5 단계, 이미지 2개 중 2개
      • This step is to prepare your spot for spray painting.
      • Add some paper around the areas you do not want paint on. Make sure you go a little past where you are going to spray paint to blend the paint into the surrounding area.
      댓글 쓰기
    6. How to Remove Rust on Car Body: 6 단계, 이미지 3개 중 1개 How to Remove Rust on Car Body: 6 단계, 이미지 3개 중 2개 How to Remove Rust on Car Body: 6 단계, 이미지 3개 중 3개
      • Spray three even coats of primer, waiting at least five minutes between each coat.
      • Let the third coat sit for 15 minutes.
      댓글 쓰기
    7. How to Remove Rust on Car Body: 7 단계, 이미지 3개 중 1개 How to Remove Rust on Car Body: 7 단계, 이미지 3개 중 2개 How to Remove Rust on Car Body: 7 단계, 이미지 3개 중 3개
      • Spray three even coats of paint on top of the primer, waiting five minutes between each coat.
      • You can either use a color similar to your car or you can get the actual color of you car by looking for the car's color code.
      • After the final coat, wait 24 hours before removing the surrounding paper.
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Robert Gutierrez
회원 가입일: 08/25/22
199 평판
안내서 1개를 작성함
CSU Los Angeles, Team 10-20, Briggs Fall 2022 CSU Los Angeles, Team 10-20, Briggs Fall 2022 회원
CSULA-BRIGGS-F22S10G20
1 회원
안내서 10개를 작성함
1가이드 댓글
Good guide, also recommending ChrisFix's video relating to this: https://www.youtube.com/watch?v=n4vusY2-...
Fixing Person - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 41
지난 30일: 166
전체 시간: 4,735
