주요 콘텐츠로 건너뛰기
How to Remove Scratches from a Car's Interior
필요한 것
  1. How to Remove Scratches from a Car's Interior, How to Remove Scratches from a Car's Interior: 1 단계, 이미지 1/2 How to Remove Scratches from a Car's Interior, How to Remove Scratches from a Car's Interior: 1 단계, 이미지 2/2
    • Clean the area around the scratch with the interior cleaner.
    • By removing the dirt, you will keep the debris from melting into the plastic and it will result in a smooth finish.
  2. How to Remove Scratches from a Car's Interior: 2 단계, 이미지 1/2 How to Remove Scratches from a Car's Interior: 2 단계, 이미지 2/2
    • Using the heat gun, gently apply heat to the plastic until it begins to soften.
    • Don't leave it on too long or else the plastic will burn and warp.
    • The plastic is ready for molding when it loses its texture and becomes slightly glossy.
  3. How to Remove Scratches from a Car's Interior: 3 단계, 이미지 1/1
    • Apply the grain pad to the intended area using light pressure.
    • This should smooth out the scratch and will give a textured finish that will blend in with the rest of the panel.
    • Make sure you use a grain pad that closely resembles the trim of your car.
  4. How to Remove Scratches from a Car's Interior: 4 단계, 이미지 1/1
    • Let the area cool and harden.
    • The texture should now look similar to the unaffected area.
  5. How to Remove Scratches from a Car's Interior: 5 단계, 이미지 1/1
    • Use a super- fine grain sandpaper to sand out the area, making it smooth and authentic looking.
  6. How to Remove Scratches from a Car's Interior: 6 단계, 이미지 1/1
    • Clean and dry the area again using the same method as in step 1 (the interior cleaner) and you're done!
결론
By following these steps you will be able to remove scratches from your cars interior.
Ryan Vogt
회원 가입일: 10/08/20
159 평판
안내서 1개 작성함
댓글 2개
what brand of grain pads do you recommend? having a difficult time finding them onlinw
Ron Beyer - 답글
Any luck finding “grain texture” pads?
ChrisB - 답글
댓글 쓰기
조회 통계:
24 시간 전: 117
7일 전: 883
30일 전: 4,609
전체 시간: 79,204
