주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Remove Scratches from a Car's Interior
필요한 것
    1. How to Remove Scratches from a Car's Interior, How to Remove Scratches from a Car's Interior: 1 단계, 이미지 2개 중 1개 How to Remove Scratches from a Car's Interior, How to Remove Scratches from a Car's Interior: 1 단계, 이미지 2개 중 2개
      • Clean the area around the scratch with the interior cleaner.
      • By removing the dirt, you will keep the debris from melting into the plastic and it will result in a smooth finish.
      댓글 쓰기
    2. How to Remove Scratches from a Car's Interior: 2 단계, 이미지 2개 중 1개 How to Remove Scratches from a Car's Interior: 2 단계, 이미지 2개 중 2개
      • Using the heat gun, gently apply heat to the plastic until it begins to soften.
      • Don't leave it on too long or else the plastic will burn and warp.
      • The plastic is ready for molding when it loses its texture and becomes slightly glossy.
      댓글 쓰기
    3. How to Remove Scratches from a Car's Interior: 3 단계, 이미지 1개 중 1개
      • Apply the grain pad to the intended area using light pressure.
      • This should smooth out the scratch and will give a textured finish that will blend in with the rest of the panel.
      • Make sure you use a grain pad that closely resembles the trim of your car.
      댓글 쓰기
    4. How to Remove Scratches from a Car's Interior: 4 단계, 이미지 1개 중 1개
      • Let the area cool and harden.
      • The texture should now look similar to the unaffected area.
      댓글 쓰기
    5. How to Remove Scratches from a Car's Interior: 5 단계, 이미지 1개 중 1개
      • Use a super- fine grain sandpaper to sand out the area, making it smooth and authentic looking.
      댓글 쓰기
    6. How to Remove Scratches from a Car's Interior: 6 단계, 이미지 1개 중 1개
      • Clean and dry the area again using the same method as in step 1 (the interior cleaner) and you're done!
      댓글 쓰기
결론
By following these steps you will be able to remove scratches from your cars interior.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Ryan Vogt
회원 가입일: 10/08/20
180 평판
안내서 1개를 작성함
5가이드 댓글
what brand of grain pads do you recommend? having a difficult time finding them onlinw
Ron Beyer - 답글 공유
Any luck finding “grain texture” pads?
ChrisB - 답글 공유
i cant find any Grain pads / stamps online
Flow_Fire - 답글 공유
have someone tried this trick and made it work?
Munir Ahmed - 답글 공유
Ustedes hacen este trabajo
Emely Caraballo - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 45
지난 7일: 305
지난 30일: 1,563
전체 시간: 144,228
