주요 콘텐츠로 건너뛰기
How to Remove Stains From a Porcelain Sink
필요한 것
  1. How to Remove Stains From a Porcelain Sink, How to Remove Stains From a Porcelain Sink: 1 단계, 이미지 2개 중 1개 How to Remove Stains From a Porcelain Sink, How to Remove Stains From a Porcelain Sink: 1 단계, 이미지 2개 중 2개
    • Sprinkle water on the sink and use a paper towel to wipe the sink.
    • The sink needs to be a little damp before starting the process so make sure you do not dry it completely.
  2. How to Remove Stains From a Porcelain Sink: 2 단계, 이미지 2개 중 1개 How to Remove Stains From a Porcelain Sink: 2 단계, 이미지 2개 중 2개
    • Wear a pair of Vinyl or your cleaning gloves and then sprinkle the baking soda on the damp sink.
    • It is recommended to use a bowl for baking soda. If you use the box directly, you can accidentally drop too much baking soda on the sink.
  3. How to Remove Stains From a Porcelain Sink: 3 단계, 이미지 2개 중 1개 How to Remove Stains From a Porcelain Sink: 3 단계, 이미지 2개 중 2개
    • Take a wet sponge and use it to scrub the sink in circular motions. Scrub the harder stains with slightly more force.
    • Make sure you squeeze the sponge beforehand to take out excess water so it is easier to scrub.
  4. How to Remove Stains From a Porcelain Sink: 4 단계, 이미지 1개 중 1개
    • Wait for 2 minutes and then spray hydrogen peroxide over the sink.
    • If you cannot find hydrogen peroxide then you can also use liquid oxygen bleach as a substitute.
  5. How to Remove Stains From a Porcelain Sink: 5 단계, 이미지 1개 중 1개
    • Scrub again for another 2-3 minutes. Try to scrub the hard stains with a little force.
  6. How to Remove Stains From a Porcelain Sink: 6 단계, 이미지 3개 중 1개 How to Remove Stains From a Porcelain Sink: 6 단계, 이미지 3개 중 2개 How to Remove Stains From a Porcelain Sink: 6 단계, 이미지 3개 중 3개
    • Take half a lime/lemon and dip it in baking soda and then use it to clean any leftover rust stains.
    • Scrub for 2-3 minutes.
    • This step will also remove the peroxide/bleach smell.
  7. How to Remove Stains From a Porcelain Sink: 7 단계, 이미지 2개 중 1개 How to Remove Stains From a Porcelain Sink: 7 단계, 이미지 2개 중 2개
    • Turn the tap on and use the sponge to wipe any leftover stains and residue from baking soda or lemon.
결론
The steps in this guide can be repeated often on the sink in order to avoid any lasting stains.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Nishtha Malhotra
회원 가입일: 01/17/21
175 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 16
지난 30일: 50
전체 시간: 2,833
