주요 콘텐츠로 건너뛰기
How to Remove Stickers From a Car
필요한 것
  1. How to Remove Stickers From a Car, How to Remove Stickers From a Car: 1 단계, 이미지 1개 중 1개
    • First of all, find the area where the sticker is. In my case, it is on the car body near the fuel tank.
  2. How to Remove Stickers From a Car: 2 단계, 이미지 2개 중 1개 How to Remove Stickers From a Car: 2 단계, 이미지 2개 중 2개
    • Spray the area with some soap water or with cleaning sprays. Goo gone work really well for this and might allow you to skip the blow dryer in the next step.
  3. How to Remove Stickers From a Car: 3 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Microfiber Cleaning Cloths
    $3.99
    • Next, wipe the area thoroughly with a microfiber cleaning cloth. Skip this step if you're using Goo Gone.
  4. How to Remove Stickers From a Car: 4 단계, 이미지 2개 중 1개 How to Remove Stickers From a Car: 4 단계, 이미지 2개 중 2개
    • Turn on the hairdryer and put it in its hot setting.
    • Start heating the sticker from a few inches away. Try to heat the sticker from the center outward.
    • This will soften the adhesive under the sticker and make the following steps much easier.
    • Using Goo Gone might allow you to skip this step, but for stubborn stickers, the hair dryer + Goo Gone will be most effective.
  5. How to Remove Stickers From a Car: 5 단계, 이미지 3개 중 1개 How to Remove Stickers From a Car: 5 단계, 이미지 3개 중 2개 How to Remove Stickers From a Car: 5 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    • Use a plastic card and try to scrape the sticker from the edges.
    • A plastic card can help you remove your unwanted stickers without damaging the paint.
    • If it doesn't work, try to repeat step 4 and then try again.
    • If you are working on a glass surface, use a razor blade instead of a plastic card! It may seem too much for the glass, but the glass is hard enough to use a razor blade on.
    • Be careful when using a razor blade!
  6. How to Remove Stickers From a Car: 6 단계, 이미지 2개 중 1개 How to Remove Stickers From a Car: 6 단계, 이미지 2개 중 2개
    • Finally, if there is any residue, heat the residue with the hairdryer and scrape it off with a plastic card or razor blade (depending on where the sticker is). Using Goo Gone makes removing any residue easy.
    • After removing all stickers and residue, use some detailing spray or cleaning spray to clean the area again and you are all set!
결론
After these steps, you should have a clean surface without any residues!
작성자
3다른 기여자 명과 함께
Xuanfang Gao
회원 가입일: 09/15/21
141 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 16
지난 30일: 24
전체 시간: 961
