주요 콘텐츠로 건너뛰기
How to Remove Wax From Clothing
필요한 것
  1. How to Remove Wax From Clothing, Removing Dried Wax: 1 단계, 이미지 1/1
    • Set up the ironing board.
    • Plug in the iron and turn it on.
    • Your iron may need some time to heat up, especially if it is an older model.
  2. How to Remove Wax From Clothing: 2 단계, 이미지 1/1
    • Place your piece of clothing onto the ironing board.
  3. How to Remove Wax From Clothing: 3 단계, 이미지 1/2 How to Remove Wax From Clothing: 3 단계, 이미지 2/2
    • Take your brown paper bag and fold it over the affected area, being sure to cover both sides of the waxy clothing.
  4. How to Remove Wax From Clothing: 4 단계, 이미지 1/1
    • Press the iron on top of the brown paper bag.
    • Move the iron around as if you are ironing wrinkles out.
    • Be careful not to burn your fingers.
  5. How to Remove Wax From Clothing: 5 단계, 이미지 1/2 How to Remove Wax From Clothing: 5 단계, 이미지 2/2
    • Lift up the brown paper bag once it looks like the oil has saturated the bag.
    • Repeat steps 3-5 with new bags, until the remainder of the wax is soaked up.
  6. How to Remove Wax From Clothing: 6 단계, 이미지 1/1
    • Feel free to wash your item now that the wax is removed, just as you normally would.
결론
To finish getting wax out it is not a bad idea to wash your item, if possible, in a washing machine for a clothing item or use carpet wash for the carpet.
Molly Green
회원 가입일: 04/23/20
133 평판
안내서 1개 작성함
UW Tacoma, Team S1-G7, Cardinal Spring 2020 UW Tacoma, Team S1-G7, Cardinal Spring 2020 회원
UWT-CARDINAL-S20S1G7
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 16
30일 전: 38
전체 시간: 531
