주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Remove a Blood Stain from Satin
필요한 것
    1. How to Remove a Blood Stain from Satin, How to Remove a Blood Stain from Satin: 1 단계, 이미지 2개 중 1개 How to Remove a Blood Stain from Satin, How to Remove a Blood Stain from Satin: 1 단계, 이미지 2개 중 2개
      • Dip the stained fabric in bowl of cold water.
      • Massage the stain while submerged for about 20 seconds to ensure that it is fully saturated.
      댓글 쓰기
    2. How to Remove a Blood Stain from Satin: 2 단계, 이미지 1개 중 1개
      • Pour laundry detergent or dish soap into bowl.
      • Amount poured should equate to approximately 1/2 cup (120ml). Larger stains may require higher quantities.
      댓글 쓰기
    3. How to Remove a Blood Stain from Satin: 3 단계, 이미지 2개 중 1개 How to Remove a Blood Stain from Satin: 3 단계, 이미지 2개 중 2개
      • Wet a clean, dry cloth or sponge in the bowl.
      댓글 쓰기
    4. How to Remove a Blood Stain from Satin: 4 단계, 이미지 2개 중 1개 How to Remove a Blood Stain from Satin: 4 단계, 이미지 2개 중 2개
      • Dab the stain gently by repeatedly pressing the wet cloth or sponge against it.
      • Rubbing the stain may further spread it and/or embed it deeper in the fabric.
      댓글 쓰기
    5. How to Remove a Blood Stain from Satin: 5 단계, 이미지 2개 중 1개 How to Remove a Blood Stain from Satin: 5 단계, 이미지 2개 중 2개
      • Rinse the stain with cold water.
      • Inspect to determine whether further cleaning is required.
      댓글 쓰기
    6. How to Remove a Blood Stain from Satin: 6 단계, 이미지 1개 중 1개
      • Add a few drops of vinegar or hydrogen peroxide to the initial solution if the stain persists.
      • Repeat steps 3 and 4.
      • The combination of these chemicals creates peracetic acid. Do not mix hydrogen peroxide and vinegar.
      댓글 쓰기
    7. How to Remove a Blood Stain from Satin: 7 단계, 이미지 1개 중 1개
      • Rinse the garment in a bowl of clean water.
      댓글 쓰기
결론
Repeat as needed until the stain is gone.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Malak Elsayed Elghobashy
회원 가입일: 02/06/25
145 평판
안내서 1개를 작성함
York University, Team 1-1, Morris Winter 2025 York University, Team 1-1, Morris Winter 2025 회원
YORK-MORRIS-W25S1G1
5 회원들
안내서 11개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 45
지난 30일: 118
전체 시간: 1,717
