주요 콘텐츠로 건너뛰기
How to Remove a Broken and Embedded Screw
필요한 것
  1. How to Remove a Broken and Embedded Screw, How to Remove a Broken and Embedded Screw: 1 단계, 이미지 1/1
    • Use an angle grinder to grind the tip of the broken screw until its surface is smooth and even.
  2. How to Remove a Broken and Embedded Screw: 2 단계, 이미지 1/2 How to Remove a Broken and Embedded Screw: 2 단계, 이미지 2/2
    • Place a center punch in the middle of the tip of the screw.
    • Use a hammer to hit the center punch to make a dent in the center of the embedded screw.
  3. How to Remove a Broken and Embedded Screw: 3 단계, 이미지 1/3 How to Remove a Broken and Embedded Screw: 3 단계, 이미지 2/3 How to Remove a Broken and Embedded Screw: 3 단계, 이미지 3/3
    • Place a center drill bit in the dent made in the previous step and start drilling until it expands enough to fit the standard drill bit inside it.
    • Always keep the drill bit at a 90 degree angle to the surface of the screw since tilting it can bend and break its tip.
  4. How to Remove a Broken and Embedded Screw: 4 단계, 이미지 1/3 How to Remove a Broken and Embedded Screw: 4 단계, 이미지 2/3 How to Remove a Broken and Embedded Screw: 4 단계, 이미지 3/3
    • Make a hole in the tip of the screw by drilling with a standard drill bit.
    • Keep drilling until the hole reaches near the end of the screw.
  5. How to Remove a Broken and Embedded Screw: 5 단계, 이미지 1/2 How to Remove a Broken and Embedded Screw: 5 단계, 이미지 2/2
    • Insert a screw extractor in the hole and then hammer it inside, making sure it is tight.
  6. How to Remove a Broken and Embedded Screw: 6 단계, 이미지 1/3 How to Remove a Broken and Embedded Screw: 6 단계, 이미지 2/3 How to Remove a Broken and Embedded Screw: 6 단계, 이미지 3/3
    • Using a wrench, unscrew the extractor.
    • The screw will come along with it, freeing the hole.
  7. How to Remove a Broken and Embedded Screw: 7 단계, 이미지 1/2 How to Remove a Broken and Embedded Screw: 7 단계, 이미지 2/2
    • Screw the new screw inside the freed hole.
결승점
다른 3명이 해당 안내서를 완성하였습니다.
Ismael Diaz
회원 가입일: 10/06/21
217 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 27
7일 전: 124
30일 전: 463
전체 시간: 6,583
