주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Remove a Broken and Embedded Screw
필요한 것
  1. How to Remove a Broken and Embedded Screw, How to Remove a Broken and Embedded Screw: 1 단계, 이미지 1개 중 1개
    • Use an angle grinder to grind the tip of the broken screw until its surface is smooth and even.
    댓글 쓰기
  2. How to Remove a Broken and Embedded Screw: 2 단계, 이미지 2개 중 1개 How to Remove a Broken and Embedded Screw: 2 단계, 이미지 2개 중 2개
    • Place a center punch in the middle of the tip of the screw.
    • Use a hammer to hit the center punch to make a dent in the center of the embedded screw.
    댓글 쓰기
  3. How to Remove a Broken and Embedded Screw: 3 단계, 이미지 3개 중 1개 How to Remove a Broken and Embedded Screw: 3 단계, 이미지 3개 중 2개 How to Remove a Broken and Embedded Screw: 3 단계, 이미지 3개 중 3개
    • Place a center drill bit in the dent made in the previous step and start drilling until it expands enough to fit the standard drill bit inside it.
    • Always keep the drill bit at a 90 degree angle to the surface of the screw since tilting it can bend and break its tip.
    댓글 쓰기
  4. How to Remove a Broken and Embedded Screw: 4 단계, 이미지 3개 중 1개 How to Remove a Broken and Embedded Screw: 4 단계, 이미지 3개 중 2개 How to Remove a Broken and Embedded Screw: 4 단계, 이미지 3개 중 3개
    • Make a hole in the tip of the screw by drilling with a standard drill bit.
    • Keep drilling until the hole reaches near the end of the screw.
    댓글 쓰기
  5. How to Remove a Broken and Embedded Screw: 5 단계, 이미지 2개 중 1개 How to Remove a Broken and Embedded Screw: 5 단계, 이미지 2개 중 2개
    • Insert a screw extractor in the hole and then hammer it inside, making sure it is tight.
    댓글 쓰기
  6. How to Remove a Broken and Embedded Screw: 6 단계, 이미지 3개 중 1개 How to Remove a Broken and Embedded Screw: 6 단계, 이미지 3개 중 2개 How to Remove a Broken and Embedded Screw: 6 단계, 이미지 3개 중 3개
    • Using a wrench, unscrew the extractor.
    • The screw will come along with it, freeing the hole.
    댓글 쓰기
  7. How to Remove a Broken and Embedded Screw: 7 단계, 이미지 2개 중 1개 How to Remove a Broken and Embedded Screw: 7 단계, 이미지 2개 중 2개
    • Screw the new screw inside the freed hole.
    댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Ismael Diaz
회원 가입일: 10/06/21
241 평판
안내서 1개를 작성함
1가이드 댓글
It all sounds great, but... It didn't work. I have a Porter-Cable older router. The first screw in the base came out without a problem, and the other 2 screws wouldn't budge. I tried various penetrating oils and nothing. I drilled one of the screws and tried an extractor...nothing. I cut off the screw and drilled clean through, then tried the extractor again...nothing. So, what's left of the screw is drilled out, won't budge with a hole, and is laughing at me.
Although I haven't tried it yet, I was going to cut of the base, leaving the screw intact, getting some vise grips and try to twist it out.
Any other ideas??
frustrated home improvement - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 13
지난 7일: 110
지난 30일: 448
전체 시간: 21,210
