주요 콘텐츠로 건너뛰기
How to Remove a Car Stereo in a Chevy Tracker
필요한 것
  1. How to Remove a Car Stereo in a Chevy Tracker, How to Remove a Car Stereo in a Chevy Tracker: 1 단계, 이미지 2개 중 1개 How to Remove a Car Stereo in a Chevy Tracker, How to Remove a Car Stereo in a Chevy Tracker: 1 단계, 이미지 2개 중 2개
    • First, you must disconnect the negative end of the car battery.
    • You will potentially be shocked if you mishandle the battery. Make sure the car is off before inspecting the engine and grabbing the negative connector.
    • Open the hood of your car and locate the battery.
    • Look for the negative end of your battery. It is usually indicated with a minus sign next to it.
    • Disconnecting the negative connection prevents you from receiving any electrical shocks while removing the stereo.
  2. How to Remove a Car Stereo in a Chevy Tracker: 2 단계, 이미지 3개 중 1개 How to Remove a Car Stereo in a Chevy Tracker: 2 단계, 이미지 3개 중 2개 How to Remove a Car Stereo in a Chevy Tracker: 2 단계, 이미지 3개 중 3개
    • Use a socket wrench to remove the nut that holds the negative connector in place.
    • Place the negative connector away from the battery.
  3. How to Remove a Car Stereo in a Chevy Tracker: 3 단계, 이미지 3개 중 1개 How to Remove a Car Stereo in a Chevy Tracker: 3 단계, 이미지 3개 중 2개 How to Remove a Car Stereo in a Chevy Tracker: 3 단계, 이미지 3개 중 3개
    • A Chevy Tracker will have a trim that surrounds the stereo.
    • The trim is the black plastic that encompasses the stereo and the small tray/compartment.
    • Remove the screw located on the underside of the trim above the car stereo.
  4. How to Remove a Car Stereo in a Chevy Tracker: 4 단계, 이미지 3개 중 1개 How to Remove a Car Stereo in a Chevy Tracker: 4 단계, 이미지 3개 중 2개 How to Remove a Car Stereo in a Chevy Tracker: 4 단계, 이미지 3개 중 3개
    • Unscrew the two screws hidden behind the tiny tray/compartment.
    • Afterwards, you can safely remove the trim.
  5. How to Remove a Car Stereo in a Chevy Tracker: 5 단계, 이미지 3개 중 1개 How to Remove a Car Stereo in a Chevy Tracker: 5 단계, 이미지 3개 중 2개 How to Remove a Car Stereo in a Chevy Tracker: 5 단계, 이미지 3개 중 3개
    • Once the trim is removed, remove the four screws found on each corner of the stereo.
  6. How to Remove a Car Stereo in a Chevy Tracker: 6 단계, 이미지 3개 중 1개 How to Remove a Car Stereo in a Chevy Tracker: 6 단계, 이미지 3개 중 2개 How to Remove a Car Stereo in a Chevy Tracker: 6 단계, 이미지 3개 중 3개
    • Carefully remove the stereo.
    • Look behind the stereo to see how it is connected.
    • The grouped up, different colored collection of wires connect to the speakers, amplifiers, and stereo buttons depending on the color.
    • The thick, metal wire connects to the car antennae.
    • Don't pull too hard! There are connections to the radio that we need to unplug.
  7. How to Remove a Car Stereo in a Chevy Tracker: 7 단계, 이미지 3개 중 1개 How to Remove a Car Stereo in a Chevy Tracker: 7 단계, 이미지 3개 중 2개 How to Remove a Car Stereo in a Chevy Tracker: 7 단계, 이미지 3개 중 3개
    • Unplugging the connections, except for the multicolored group of wires. All are located on the back of stereo should be as simple as pulling on them.
    • "To remove the group of wires", follow the wires until you reach a connector and unplug the connector.
    • The thick, metal wire connecting to the radio antennae can be easily removed by pulling on it.
    • The harness (the grayish female connector circled in red) is what connects the wires to the various components of the car.
  8. How to Remove a Car Stereo in a Chevy Tracker: 8 단계, 이미지 2개 중 1개 How to Remove a Car Stereo in a Chevy Tracker: 8 단계, 이미지 2개 중 2개
    • Some car stereos are attached to a mount.
    • Each mount is similarly installed as the image shows.
    • Remove the screws located on each side of the mount.
  9. How to Remove a Car Stereo in a Chevy Tracker: 9 단계, 이미지 1개 중 1개
    • You have now successfully uninstalled a car stereo from a Chevy Tracker!
    • Do not forget to reconnect the negative connector to the battery when finished!
결론
Following the steps in reverse will reinstall your car stereo. Different car stereos might require extra connections to be installed.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Nick Eaton
회원 가입일: 09/29/15
211 평판
안내서 1개를 작성함
Cal Poly, Team 15-4, Green Fall 2015 Cal Poly, Team 15-4, Green Fall 2015 회원
CPSU-GREEN-F15S15G4
4 회원들
안내서 4개를 작성함
1가이드 댓글
Ended up blowing a fuse for my taillights and dash lights. I replaced fuse, however still not coming back on. Any suggestions as to why?
Brandy - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 16
지난 30일: 42
전체 시간: 7,686
