주요 콘텐츠로 건너뛰기
How to Remove a Deodorant Stain From a Shirt
필요한 것
  1. How to Remove a Deodorant Stain From a Shirt, How to Remove a Deodorant Stain From a Shirt: 1 단계, 이미지 3개 중 1개 How to Remove a Deodorant Stain From a Shirt, How to Remove a Deodorant Stain From a Shirt: 1 단계, 이미지 3개 중 2개 How to Remove a Deodorant Stain From a Shirt, How to Remove a Deodorant Stain From a Shirt: 1 단계, 이미지 3개 중 3개
    • Measure two cups of water.
    • Pour the water into a bowl large enough to soak the garment.
  2. How to Remove a Deodorant Stain From a Shirt: 2 단계, 이미지 2개 중 1개 How to Remove a Deodorant Stain From a Shirt: 2 단계, 이미지 2개 중 2개
    • Measure 1 cup of white vinegar.
    • Pour the white vinegar into the same bowl with the cup of water.
  3. How to Remove a Deodorant Stain From a Shirt: 3 단계, 이미지 2개 중 1개 How to Remove a Deodorant Stain From a Shirt: 3 단계, 이미지 2개 중 2개
    • Soak the garment with the stain in the bowl for 30 minutes.
  4. How to Remove a Deodorant Stain From a Shirt: 4 단계, 이미지 3개 중 1개 How to Remove a Deodorant Stain From a Shirt: 4 단계, 이미지 3개 중 2개 How to Remove a Deodorant Stain From a Shirt: 4 단계, 이미지 3개 중 3개
    • Measure and mix the following ingredients into a small bowl:
    • Half a cup of baking soda.
    • A tablespoon of salt.
    • A tablespoon of hydrogen peroxide.
  5. How to Remove a Deodorant Stain From a Shirt: 5 단계, 이미지 1개 중 1개
    • Mix the baking soda, salt, and peroxide combination with a small utensil until the ingredients have been thoroughly combined.
    • The result should be a somewhat gritty paste.
  6. How to Remove a Deodorant Stain From a Shirt: 6 단계, 이미지 1개 중 1개
    • Wring out the shirt and apply the paste to the stain.
    • Be sure to knead the mixture into the fabric to ensure that all of the threads have been exposed.
    • Leave the shirt idle for 20 minutes.
  7. How to Remove a Deodorant Stain From a Shirt: 7 단계, 이미지 1개 중 1개
    • Wash off the excess paste.
    • Wash the garment in a normal wash cycle.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jeffrey Okhuozagbon
회원 가입일: 10/02/20
160 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 29
전체 시간: 977
