주요 콘텐츠로 건너뛰기
How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation)
필요한 것
  1. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation), How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 1 단계, 이미지 1/2 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation), How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 1 단계, 이미지 2/2
    • On the top of the printer, turn the injector counter-clockwise and pull the tab.
  2. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 2 단계, 이미지 1/3 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 2 단계, 이미지 2/3 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 2 단계, 이미지 3/3
    • Insert your fingers in the center of the filament cartridge and slowly pull it away from the printer.
  3. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 3 단계, 이미지 1/1
    • Place the cartridge face up and pry off the lid of the cartridge.
  4. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 4 단계, 이미지 1/2 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 4 단계, 이미지 2/2
    • Gently flip the cartridge on its front and remove the two 2mm Hex screws using a Hex key.
  5. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 5 단계, 이미지 1/1
    • Flip the cartridge face up and remove the gearbox and extractor tube.
  6. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 6 단계, 이미지 1/3 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 6 단계, 이미지 2/3 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 6 단계, 이미지 3/3
    • Place your thumb on the front of the injector head and your middle finger on the needle.
    • Firmly pull the needle towards your thumb until the injector head cases cracks and pulls apart the case.
  7. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 7 단계, 이미지 1/2 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 7 단계, 이미지 2/2
    • Heat the needle using a lighter, making sure that the flame does not touch the needle.
    • Using needle-nose pliers, pull the needle from the tube.
    • Do not touch the needle as it may still be hot.
  8. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 8 단계, 이미지 1/1
    • Insert a paper clip and turn until the clog is removed.
결론
Hector Vazquez
회원 가입일: 10/23/20
157 평판
안내서 1개 작성함
CSU Los Angeles, Team S12-G11, Harris Fall 2020 CSU Los Angeles, Team S12-G11, Harris Fall 2020 회원
CSULA-HARRIS-F20S12G11
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 15
전체 시간: 514
