주요 콘텐츠로 건너뛰기
How to Remove a Label From a Glass Jar
필요한 것
  1. How to Remove a Label From a Glass Jar, How to Remove a Label From a Glass Jar: 1 단계, 이미지 1개 중 1개
    • Boil enough water to fill both glass jars.
    • Pour the boiling water into the smaller jar using a tea kettle.
    • The hot water will heat up the glass and melt the adhesive from the inside.
  2. How to Remove a Label From a Glass Jar: 2 단계, 이미지 2개 중 1개 How to Remove a Label From a Glass Jar: 2 단계, 이미지 2개 중 2개
    • Place the lid onto the jar and tighten.
    • This step is optional if the larger container in Step 3 has a lid.
  3. How to Remove a Label From a Glass Jar: 3 단계, 이미지 2개 중 1개 How to Remove a Label From a Glass Jar: 3 단계, 이미지 2개 중 2개
    • Place the jar into a larger glass container.
  4. How to Remove a Label From a Glass Jar: 4 단계, 이미지 1개 중 1개
    • Pour hot water into the larger jar until the water level is above the label.
  5. How to Remove a Label From a Glass Jar: 5 단계, 이미지 1개 중 1개
    • Add a few drops of dish soap into the larger jar.
    • This helps to clean up residue from the label.
  6. How to Remove a Label From a Glass Jar: 6 단계, 이미지 2개 중 1개 How to Remove a Label From a Glass Jar: 6 단계, 이미지 2개 중 2개
    • Place the lid on the larger container and tighten.
    • This prevents heat from leaving the container.
    • Let the container sit for 10 to 15 minutes or until completely cooled.
  7. How to Remove a Label From a Glass Jar: 7 단계, 이미지 2개 중 1개 How to Remove a Label From a Glass Jar: 7 단계, 이미지 2개 중 2개
    • Remove the smaller jar from the larger container.
    • Pour the water out of the jar.
    • Peel the label off of the jar.
    • For containers with loose labels, the label will fall off or be able to be slipped off.
    • Wipe off excess residue with a cloth or paper towel.
결승점
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Ridhwan Hasnat
회원 가입일: 01/17/22
235 평판
안내서 1개를 작성함
York University, Team 1-34, O'Regan Winter 2022 York University, Team 1-34, O'Regan Winter 2022 회원
YORK-O'REGAN-W22S1G34
1 회원
안내서 4개를 작성함
1가이드 댓글
Génial ! Je n'y avais jamais pensé. Merci beaucoup !
Josette Léost - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 24
전체 시간: 819
