주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Remove a Wheel Lock Without a Key
조회수: 17만
통계 보기:
지난 24시간
44
지난 7일:
252
지난 30일:
947
전체 시간:
168,423
댓글: 8
3 comments on steps, 5 guide comments.
Go to guide comments
완료함: 10
10명이 이 안내서를 "완료"로 표시했습니다. 다음은 귀하의 차례입니까?
즐겨찾기: 0
해당 안내서에 좋아요를 누르고 구독한 사람이 아직 없습니다. 첫 번째 주인공이 되시겠습니까?
소요 시간: 30 분
난이도: 조정
If you have a wheel lock (wheel nut lock) on your car or truck wheel and do not have a wheel lock key, use this guide to remove the wheel lock.
A wheel lock is used to fasten the wheel on your vehicle, as a regular wheel nut would, but uses a part-specific key to unlock it. It is common to lose a wheel lock key. The wheel lock key can be removed manually.
Before beginning, make sure your vehicle is on a flat surface and all wheels are level. Make sure to have your emergency brake (parking brake) on as well.
필요한 것
도구
    1. How to Remove a Wheel Lock Without a Key, Wheel Lock: 1 단계, 이미지 3개 중 1개 How to Remove a Wheel Lock Without a Key, Wheel Lock: 1 단계, 이미지 3개 중 2개 How to Remove a Wheel Lock Without a Key, Wheel Lock: 1 단계, 이미지 3개 중 3개
      • Clean the wheel lock to make sure there is no debris on the surface of the lock.
      댓글 쓰기
    2. How to Remove a Wheel Lock Without a Key: 2 단계, 이미지 2개 중 1개 How to Remove a Wheel Lock Without a Key: 2 단계, 이미지 2개 중 2개
      • Find a 12-point socket that barely fits over the wheel lock.
      • The socket should not be loose enough to revolve around the wheel lock.
      댓글 쓰기
    3. How to Remove a Wheel Lock Without a Key: 3 단계, 이미지 2개 중 1개 How to Remove a Wheel Lock Without a Key: 3 단계, 이미지 2개 중 2개
      • Hold the socket in place.
      • Use a hammer to hit the socket until it is tight around the lock.
      • Gloves are recommended to prevent hand injury.
      댓글 쓰기
    4. How to Remove a Wheel Lock Without a Key: 4 단계, 이미지 2개 중 1개 How to Remove a Wheel Lock Without a Key: 4 단계, 이미지 2개 중 2개
      • Unscrew the socket using the socket wrench.
      • Turn left to loosen. If you cannot turn the wrench easily, get a longer wrench for more torque.
      댓글 쓰기
    5. How to Remove a Wheel Lock Without a Key: 5 단계, 이미지 3개 중 1개 How to Remove a Wheel Lock Without a Key: 5 단계, 이미지 3개 중 2개 How to Remove a Wheel Lock Without a Key: 5 단계, 이미지 3개 중 3개
      • Now that the wheel lock is off, it will be stuck to the socket.
      • Insert the screwdriver into the square-opening on top of the socket.
      • Hit the top of the screwdriver with the hammer a few times until the lock falls out of the socket.
      댓글 쓰기
    6. How to Remove a Wheel Lock Without a Key: 6 단계, 이미지 3개 중 1개 How to Remove a Wheel Lock Without a Key: 6 단계, 이미지 3개 중 2개 How to Remove a Wheel Lock Without a Key: 6 단계, 이미지 3개 중 3개
      • Grab a regular wheel nut.
      • Screw on the wheel nut by hand.
      • Use the tire iron to tighten the wheel nut.
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 10명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자
Hesham Annamer
회원 가입일: 09/17/20
406 평판
안내서 1개를 작성함
5가이드 댓글
Hi, I have a 05 dodge dakota that has 4- 8 spline thin wall deep socket lug nuts on them. I have went to every tire/mechanic shop and tool store. I really need to get these off so I can change my breaks!!
If there's anything or any advice you can give on how to get these suckers off, I would greatly appreciate it 🙏🏽
As my husband has been trying for over a week now!!
SK Seid - 답글 공유
Those are really tricky to get out, i remember welding on a 17mm nut properly and then using impact to get that out son years ago, last option in usually drilling out the whole stud and socket, both options are really frustrating especially if you have expensive rims. If u can hammer on a socket a impact gun will get that out.
Nirap Singh - 답글 공유
I was skeptical, but this did in fact work on my 2005 Honda CRV spare tire wheel lock. I used a 3/4 inch 12 point socket. Hammered it on and it came off easily. Can't get the wheel lock nut out of the socket, but well worth losing a socket to get off the nut.
Atomic Night Light - 답글 공유
I recently had the same issue. I thought I lost the key lock for my BMW. I contacted a vendor and was told they could replace it, if I sent them a picture of it. My son was taking the picture when he saw it in the loug bolt. I believe its been there for a few months .
Bill D - 답글 공유
Changer de huile de boîte automatique
Adama Mallé - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 44
지난 7일: 252
지난 30일: 947
전체 시간: 168,423
