주요 콘텐츠로 건너뛰기
How to Remove and Replace Caulk in a Bathtub
필요한 것
  1. How to Remove and Replace Caulk in a Bathtub, Replacing Caulk in Bathtub: 1 단계, 이미지 1/1
    • Remove current caulk from bathtub using a sharp tool such as a knife or utility tool. Test it first in a small area to not scrape the bathtub.
  2. How to Remove and Replace Caulk in a Bathtub: 2 단계, 이미지 1/1
    • Clean the surface and mold from the area with a putty knife. Excess caulk can be removed with a combination of liquid caulk removal. Remove the rest of the residue with a knife.
  3. How to Remove and Replace Caulk in a Bathtub: 3 단계, 이미지 1/1
    • Dry the area well to prevent mold from forming and it let it dry overnight before continuing the next step.
  4. How to Remove and Replace Caulk in a Bathtub: 4 단계, 이미지 1/2 How to Remove and Replace Caulk in a Bathtub: 4 단계, 이미지 2/2
    • Tape around the area that is going to be caulked. Place the tape 1/8 inch on either side of the seam that is going to be caulked. The tape keeps the caulk in a smooth line.
  5. How to Remove and Replace Caulk in a Bathtub: 5 단계, 이미지 1/2 How to Remove and Replace Caulk in a Bathtub: 5 단계, 이미지 2/2
    • Trim the opening of the caulk from the caulk gun to 1/8 an inch and use it a 45-degree angle and make sure it is the same size as the area between the tape.
  6. How to Remove and Replace Caulk in a Bathtub: 6 단계, 이미지 1/2 How to Remove and Replace Caulk in a Bathtub: 6 단계, 이미지 2/2
    • Load the caulk gun and use a steady pressure along the space between the tape as you move across it. An even pace is needed; if it’s too slow the caulk will pile up, and if it’s too fast it will break easily.
  7. How to Remove and Replace Caulk in a Bathtub: 7 단계, 이미지 1/1
    • Smooth out the line of caulk with your finger.
  8. How to Remove and Replace Caulk in a Bathtub: 8 단계, 이미지 1/2 How to Remove and Replace Caulk in a Bathtub: 8 단계, 이미지 2/2
    • Remove tape and fix any blemishes.
결론
If you are how unhappy how the caulk turned out; don’t worry you can just do the following the steps again as there is no permanent damage done with caulking.
Ian Johnson
회원 가입일: 03/26/20
167 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 13
30일 전: 70
전체 시간: 2,275
