주요 콘텐츠로 건너뛰기
How to Remove scratches from a CD
필요한 것
  1. How to Remove scratches from a CD, How to Remove scratches from a CD: 1 단계, 이미지 1/1
    • Identify any scratches.
    • Some scratches may be too deep to be removed. In this case, this method may not work.
  2. How to Remove scratches from a CD: 2 단계, 이미지 1/2 How to Remove scratches from a CD: 2 단계, 이미지 2/2
    • Take the CD to the sink.
    • Wash with lukewarm water to remove any dust or dirt.
  3. How to Remove scratches from a CD: 3 단계, 이미지 1/1
    • Let the CD air dry, or dry with towel.
    • Use a non-linen towel or your CD will need to be washed again.
  4. How to Remove scratches from a CD: 4 단계, 이미지 1/3 How to Remove scratches from a CD: 4 단계, 이미지 2/3 How to Remove scratches from a CD: 4 단계, 이미지 3/3
    • Take the toothpaste, and apply it to your index finger.
    • Rinse the toothpaste in lukewarm water and apply to the CD.
    • Rub toothpaste in a circular motion from the center to the outer edge.
    • Add multiple layers of toothpaste to cover all of the scratches.
    • Use a white toothpaste, not a gel. Gels containing little beads may cause more damage to the CD.
  5. How to Remove scratches from a CD: 5 단계, 이미지 1/1
    • Let the CD sit for 2 to 3 minutes.
    Unless I’m missing something, If you’re using toothpaste to polish the scratches out of a CD, there’s no need to let it sit with the paste on it. It’s the circular motion moving the aggregate in the paste that is removing the scratches.
    Jimmy Hoffa - 답글
  6. How to Remove scratches from a CD: 6 단계, 이미지 1/1
    • Rinse off the toothpaste with lukewarm water.
  7. How to Remove scratches from a CD: 7 단계, 이미지 1/1
    • Let the CD air dry, or dry with a non-linen towel.
  8. How to Remove scratches from a CD: 8 단계, 이미지 1/1
    • Inspect your disk.
    • If your disk still has scratches, repeat the process.
    • You could also try to burn the disk onto another disk if the disk is lagging.
결론
다른 40명이 해당 안내서를 완성하였습니다.
Nick Jones
회원 가입일: 09/29/15
1,389 평판
안내서 1개 작성함
Cal Poly, Team 14-4, Green Fall 2015 Cal Poly, Team 14-4, Green Fall 2015 회원
CPSU-GREEN-F15S14G4
5 회원들
안내서 16개 작성하였습니다
댓글 5개
thank youuuuuuuuu
aboabdo.2007 - 답글
Funziona anche con i DVD di film e videogiochi questo procedimento? Oppure è solo specifico per i CD?
Francesco Pepe - 답글
It did not work for me
Leisy Madrigal - 답글
Me Funciono muy bien, gracias!
Esteban Montero - 답글
댓글 쓰기
조회 통계:
24 시간 전: 43
7일 전: 268
30일 전: 1,094
전체 시간: 56,707
