주요 콘텐츠로 건너뛰기
How to Remove the Back Plate of a TI-NSpire
필요한 것
  1. How to Remove the Back Plate of a TI-NSpire, How to Remove the Back Plate of a TI-NSpire: 1 단계, 이미지 1/1
    • Place the calculator screen facing down, with the back plate facing up.
  2. How to Remove the Back Plate of a TI-NSpire: 2 단계, 이미지 1/1
    • Remove the six 7.3 mm screws from the back of the calculator using a Phillips #000 screwdriver.
  3. How to Remove the Back Plate of a TI-NSpire: 3 단계, 이미지 1/3 How to Remove the Back Plate of a TI-NSpire: 3 단계, 이미지 2/3 How to Remove the Back Plate of a TI-NSpire: 3 단계, 이미지 3/3
    • Slide the latch to the right to release the keypad.
    • Pull the keypad down at the same time.
  4. How to Remove the Back Plate of a TI-NSpire: 4 단계, 이미지 1/1
    • Remove the screw near the bottom of the calculator on the front side.
    • The screw is behind where the keyboard normally sits.
  5. How to Remove the Back Plate of a TI-NSpire: 5 단계, 이미지 1/3 How to Remove the Back Plate of a TI-NSpire: 5 단계, 이미지 2/3 How to Remove the Back Plate of a TI-NSpire: 5 단계, 이미지 3/3
    • Turn the calculator over so the back plate faces up.
    • Use the iFixit Opening Tool to carefully pry the back plate out at the bottom right corner.
    • The prying order is arbitrary. The importance is to pry across the length of the calculator.
    • Repeat the prying step on the middle right side, moving along the perimeter of the calculator.
    • Repeat the prying step on the top right corner.
  6. How to Remove the Back Plate of a TI-NSpire: 6 단계, 이미지 1/1
    • Use your hands to manually separate the now loosened back plate from the calculator.
결론
To reassemble your device, carefully push the back plate back onto the calculator. Then replace the screws back into the back plate.
다른 한 분이 해당 안내서를 완성하였습니다.
John Baek
회원 가입일: 09/27/12
31 평판
안내서 4개 작성하였습니다
Cal Poly, Team 7-52, Forte Fall 2012 Cal Poly, Team 7-52, Forte Fall 2012 회원
CPSU-FORTE-F12S7G52
5 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 19
전체 시간: 4,497
