소개
Use this guide to replace the front panel in your Whirlpool Refrigerator.
The front panel covers the front bottom edge of the refrigerator. You need to remove this panel in order to access some components, such as the drain pan and condenser coils.
This guide will work for most Whirlpool refrigerators. This guide is written with a model WRS315SDHW refrigerator. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
필요한 것
Repair didn’t go as planned? Ask our Answers community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
Woah, felicidades tío!
Cayó un whirlpool hace unos meses en mis manos y li resolví gracias a ti.
Ahora tengo otro whirlpool ARC7470 y no enfría, bien...motor ok pero termostato muerto.
Es el n⁰ de pieza: Whirlpool C00312889
Pero no se cambiarlo. Saque el panel de temperatura pero no doy con donde esta y menos como lo puedo cambiar. #HELP.
GRACIAS!🙂
